AIR Removal 2000 Camaro SS PICS
Old Sep 27, 2008 | 08:11 PM
neil1b's Avatar
Default AIR Removal 2000 Camaro SS PICS
Hi All,
After searching through the forums and posts, I discovered excellent wrip up detailing the removal. The guide, however did not cover the "extra" pieces as equipped on the 2000 model year. I have taken a few pictures of the whole unit removed and how I chose to deal with the vacuum line in the back of the manifold.
Below are the pictures of the AIR System removed as well as the EGR and the old LS1 coolant lines and LS1 manifold as I swapped to the LS6.
Hope this helps some people as I had great difficulty understanding the vacuum line "posts" on what to plug, remove, etc.
Old Sep 27, 2008 | 08:12 PM
neil1b's Avatar
Default more pics
whole system
Old Sep 27, 2008 | 08:13 PM
neil1b's Avatar
Default ...........
sorry here's the pic
Old Sep 27, 2008 | 08:16 PM
neil1b's Avatar
Default Back of Manifold
Pic of rear of manifold
Old Sep 27, 2008 | 08:18 PM
neil1b's Avatar
Default Close up of electrical connection removed
more pics
Old Sep 27, 2008 | 08:22 PM
neil1b's Avatar
Default Vacuum Line situation
Here's a pic of the rear manifold vacuun lines.......if you enlarge the photo, you'll see my cruel drawing of what I took off. I removed the whole T fitting and the only vacuum line need to conect comes from the passenger side rear firewall that is used for the climate control system.
I modified the vacuum line fitting to connect directly to the rear of the manifold's single nipple eliminating the whole "T" thing....
Old Sep 27, 2008 | 10:55 PM
Bad06SS's Avatar
Great job, and thanks for the pics! I plan to remove mine soon.
Old Sep 28, 2008 | 12:40 PM
dutinsss's Avatar
great post! after you remove the T-fitting, what has to be done to slip the climate control line over the map sensor?
Old Sep 28, 2008 | 12:50 PM
Mart00SS's Avatar
I did the same thing with my vacuum line, took everything off at the T and just slipped the single line right on there for the HVAC.
Old Sep 28, 2008 | 01:00 PM
dutinsss's Avatar
so the hvac line just slips right over it without the T?
Old Sep 28, 2008 | 04:40 PM
00pooterSS's Avatar
lol at your avatar
Old Sep 28, 2008 | 04:48 PM
Mart00SS's Avatar
Sure does, the piece of rubber that hooks to the T is too big I believe but if you take that off there is a smaller rubber piece on the line that will slip on the manifold at the map sensor, I didnt have to buy anything, just used what was already there.
Old Sep 28, 2008 | 04:54 PM
Predator's Avatar
That's interesting, I just plugged one of the inlets?/ outlets? in the t-fitting.
Old Sep 28, 2008 | 07:06 PM
neil1b's Avatar
Default vacuum line
if ou cut the remaining fitting back, it'll fit perfectly over the nipple on back odf the intake...
FYI
I did a ported TR throttle body with the ls6 intake swap, and the idle was high before coming down.
Make sure you do the tps reset and the idle learn to correct this problem.......hope I helped some people out with this.
Old Sep 28, 2008 | 07:11 PM
neil1b's Avatar
Default original link
https://ls1tech.com/forums/showthrea...moval+air+head
here's the original post that heped me out
PS it'll throw a couple codes after your done, so you'll need a bud with software to tune them out
Neil
Old Feb 17, 2009 | 11:32 AM
sscamaroburn02's Avatar
I'm installing the fast intake and there is the hole for the map sensor, a connection for the brake booster hose on the driver's side and a small nipple on the passenger side of intake.
I'm getting rid of the entire AIR system and was confused a little bit.
Do i need to connect anything to this small nipple on the new FAST intake or not?
The small rubber hose is just hanging there in the back of the engine. Is this the HVAC controls hose? I thought I just buy a freeze plug for this hole.
I will be installing this week so someone please help me please. Thanks
Old Feb 17, 2009 | 12:27 PM
nemss1's Avatar
if u still want the A/C controls to work, just plug up the nipple for the AIR or just install the boot frm the vacuum line directly on the nipple on the intake
if running no A/C, install a vacuum plug over the nipple on the back of the intake
Old Feb 17, 2009 | 12:31 PM
okay so since the FAST intake only has one small nipple on the rear of intake just plug the small vacuum line into it for the ac controls to work?
Old Feb 17, 2009 | 01:26 PM
nemss1's Avatar
yup, thats it
Old Feb 17, 2009 | 01:39 PM
okay thanks
