New exhaust poll
1) 3" pipe with flattened section (best ground clearance)
2) 3" pipe with no flat section (less clearance, will hit car, must put some type of cushion between pipe and floor of car to prevent contact)
3) 3" pipe with no flat section but with a bend to go under the floor brace (worse ground clearance but should clear floor of car without banging)
Just a thought.
Plus having a whored out y-pipe is all the rage.. haha.. Mine has to be the biggest ***** of them all.. everyone has had it out and beat on it a little..
As for 3, you'll probably hate life if you go that route.. haha...
Anyway, there may be a new y pipe and a set of duals out soon.
Once I get the prototype systems done I will post pics and see if there is a market big enough for them for me to justify paying the stiff sponsor fee on here to sell them.
There is going to be a y pipe using the Flowmaster merge with several options. Different merge outlet sizes, reducers, cutouts, etc.
A dual system with H pipe and some oval mufflers. Haven't decided what kind of mufflers yet.
if you put a cushion there, you're using your headers and y pipe as a motor mount.
this can make things ugly when you try to take that drivers side manifold off that aluminum head... on the positive side, you could end up needing to upgrade your heads.
3" ypipe with very minor clearanceing (flat spots). my exhaust was 1/4" from my frame and never hit under load.
forget the redneck way...do it right.
now i have 3" true duals the same way...only they aren't even clearanced.
here is a picture of how my Flowtech ypipe was clearanced:
i did some calculations. if you indent the pipe 1/2", flat across the top for clearance with the frame, you're only losing 9% of the cross sectional area of the 3" pipe.
basically you're still maintaining the equivalent flow of a 2 7/8" pipe.
still pretty damn good, more than enough to flow for even the bigger h/c motors.
Here's a picture of my PaceSetter Y pipe with a FlowMaster Merge. It helped tremendously. Killed the rasp, opened up the top end ALOT (so much that it sort of sucked a little away from the bottom end), and made it sound deeper.
Everyone should get poly mounts. Period. Stop complaining about pipes banging and just fix it. Garden hoses are for watering flowers.
Or if TSP offered a 4" true dual system they'd be all over it. The truth is, 3" piping will support us to a level of HP that 90% of us will never need. I am not, however, arguing that 3" pipe is too big. Its just right. But like it was stated before, a 9% reduction in flow wont hurt anything. People concerned with getting every last drop go with duals. The rest of us either want to control the noise a little, or have really good ground clearance at the expense of a tiny bit of top-end. Personally, I am trying to switch over to the 4" single exit Mufflex (roughly 11% less area than two 3" pipes) but mainly for the sound
