HELP!! LongTube Rattle
Old Oct 7, 2008 | 09:59 AM
gnictry's Avatar
Question HELP!! LongTube Rattle
I got obx long tubes about year and a half or so ago...car had 90k..ish on it then now has 114k
I have had this rattle in the passenger side lt for a while...just cant take it any more.
I have checked to make sure its not the o2s...u can tap the collector area with them out and stilll rattles...
Sounds like a piece of steel in it moving around but took y pipe off and put magnetic stick in there and nothing also not see anything.
Do yall think its the four pipes tapping? any ideas welcome...any things to look at welcome
Old Oct 7, 2008 | 11:47 AM
odarabla's Avatar
I had the same issue with my long tubes about 8 months after I installed them. When I changed the headers I didn't use any locktight so one of the header bolts backed out. Well it ended up in the collector of the header and after awhile it started to rattle around and make noise at certain rpms. I took it to a muffler shop, we stuck a magnet into the collector and found the bolt. Check your header bolts to see if they are all there. If they are check to make sure a rock or something didn't get caught in the collector and is rattling around in there. After that inccedent I installed Stag 8 locking bolts.
Old Oct 7, 2008 | 11:51 AM
gnictry's Avatar
ill check that....i had them unbolted when i did cam about a month ago...still there maybe a rock...ill look when i get a chance.thanks for ur reply!
Old Oct 7, 2008 | 11:59 AM
Intercooler2's Avatar
Put it up on a lift and put a screwdriver end to your ear and tip to the header one at a time. May be able to find it that way.
Old Oct 7, 2008 | 01:26 PM
KurtRardin's Avatar
Veteran: Marine Corps
We sell stethascopes really cheap at Harbor Freight tools
Old Oct 7, 2008 | 01:54 PM
Blk98ls1's Avatar
My passenger side long tube slightly taps the K-member at idle. This might be the problem?
Old Oct 7, 2008 | 06:03 PM
TheSilverOne's Avatar
so with the header bolted onto the head, a bolt backed out, went down a primary and landed in the collector?
Old Oct 7, 2008 | 07:06 PM
odarabla's Avatar
Yep!! I was sorta suprised myself.. It wasn't inside the pipe it was between them right at the collector.
Old Oct 8, 2008 | 01:10 AM
shaun's Avatar
i was about to say how in the hell did the bolt get "in" the header lol
Old Oct 8, 2008 | 08:17 AM
gnictry's Avatar
Not bolts-all there and tight
does touch the k member
Old Oct 8, 2008 | 08:18 AM
gnictry's Avatar
have not looked for a rock yet and have tried the screw driver thing before but when i get a chance to look for rock will do again...
thanks yall for replys
