Motor Mounts
Old Oct 8, 2008 | 02:09 PM
toothdoc's Avatar
Default Motor Mounts
Should I replace the motor mounts when I have my ARH 1 7/8 headers and catted-Y installed? If so, should I just put stock ones back in or should I put the poly ones in? What are the advantages of the polys over stock and what are the disadvantages? Any insight would be helpful. Thanks.
Old Oct 8, 2008 | 02:14 PM
shaun's Avatar
just about every one is going to say get the poly mounts and be done with it.
they will help or even stop your y pipe from banging and from what i read they all bang.
i put some pacesetters and a tsp ory and i even have the mufflex y pipe hanger and it bangs on the passenger side and i dident do the mounts and i wish i would of.
just do em! lol
Old Oct 9, 2008 | 11:03 AM
firehawk#682's Avatar
Do the poly motor mounts! Its alot easier to do them with the exhaust off.
Advantage is the motor doesn't rock as much when you stomp on the gas which means the y-pipe doesn't bang against the floor bloard.
Disadvantage is that the can be a little PITA to install but well worth it.
Don't do the poly trans mount tho or your car will vibrate something awful.
Old Oct 9, 2008 | 01:09 PM
toothdoc's Avatar
You guys have convinced me. The poly motor mounts were ordered this morning. It will be easy to do, as I am installing a new engine.
Old Oct 9, 2008 | 03:10 PM
TORCHD 02 TA's Avatar
When ever you are doing LTs, it is a MUST do to poly mounts at that time. take it from me. I did my LTs first then i did my poly mounts took friggin 8 hours to do b/c the LTs are in the way
Old Oct 9, 2008 | 09:42 PM
ajsfirehawk's Avatar
Same story here as TorchD. 8 hour cuss job after the header install and it fixed the banging
Old Oct 10, 2008 | 09:13 PM
Omec's Avatar
are you just saying it will vibrate w/ a poly trans mount because you know or because you read that somewhere? im pissed i waited 3 weeks after my LT and poly motor mount install to get a poly trans mount. that was the final touch to a bad *** upgrade. i get no vibrations at all and drive it on the highway 300 miles every week end. best of all my shifter doesnt wanna come outta the console and try to punch me in the face.
