Why negative LTRIMS at idle?
Old Dec 9, 2001 | 09:22 AM
CHRISPY's Avatar
Default Why negative LTRIMS at idle?
Guys I am a little confused. I am running stock descreened MAF, stock programming with HPP used only for rev limits and gearing etc.
My LTRIMS at idle at -10 on one bank and -4 on the other bank. At cruise they both go to zero. Does anyone know why this is happening?
It is running rich at idle for some reason but I cant pin down why.
I am running a MAC offroad with bullets in the Y and no catback at the present time. O2's look ok and timing is decent as well. Any ideas?
I have my AIR and EGR block off so I dont know if that would contribute to my problem or not. I may put small holes in the block off plates and see if the AIR pump functioning again will help.
Thanks,
Chris
[ December 09, 2001: Message edited by: Chris ARE 360 ]</p>
Old Dec 9, 2001 | 11:03 AM
y2khawk's Avatar
Default Re: Why negative LTRIMS at idle?
Chris
What's your fuel system setup now? High fuel pressure can send the LTRIMS south. Mine have come down quite a bit with the addition of the volt blaster. It's just a little too much flow for my regulator at idle.
Old Dec 9, 2001 | 03:01 PM
CHRISPY's Avatar
I am running the stock 98 fuel system with stock 98 injectors. <img src="images/icons/frown.gif" border="0">
Not sure why this is happening. I dont think its a vac leak as that usually increases LTRIMS at idle and not decrease them. again cruising is perfect with 0 LTRIMS but idle is -10 on one bank and -4 on the other.
Could TPS voltage or IAC have anything to do with this? Maybe an exhaust leak at idle?
Thanks,
Chris
Old Dec 10, 2001 | 12:26 AM
LS1JM's Avatar
Chris, mine are at 0 or a little negative at idle which I thought was good. At WOT I average 880's with 0 knock. Joe... <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Jan 4, 2002 | 11:40 AM
ABNRNGR (Aka Dean)'s Avatar
[quote]Originally posted by Chris ARE 360:
<strong>I am running the stock 98 fuel system with stock 98 injectors. <img src="images/icons/frown.gif" border="0">
Thanks,Chris did you ever get an answer for this? thanks,Dean
Chris</strong><hr></blockquote>
Old Jan 4, 2002 | 02:48 PM
CHRISPY's Avatar
Warm idle it is doing it.
Here is an overview of my system <img src="gr_stretch.gif" border="0">
Stock programming with HPP for rev limit, gears, and fans only. NO power tuning
Stock MAF descreened
Stock injectors
Stock pump
Stock lines
NGK TR55 plugs at .055 gap
at idle they are at -10 and -4. As soon as I start cruising they return to 0 on both banks.
soo... My car is adding a lot of fuel at idle (More than necessary) and the PCM is trying to compensate by removing fuel at idle.
Also my car is slow starting when hot sometimes, but I think that is TPS/IAC related. Mechanically everything seems very solid with the car.
Your thoughts are appreciated <img src="gr_stretch.gif" border="0">
Chris
- Maybe it is the AIR pump system. I have it unplugged but maybe the computer is not compensating for the lack of air injected by the AIR pump at startup and idle and is forcing the LTRIMS to remove fuel.
Old Jan 4, 2002 | 04:03 PM
Ragtop 99's Avatar
I noticed that with a cam (before tuning), my Ltrims at idle were off much more than any other cell.
Could misfires at idle cause the O2s to look rich so the computer pulls extra fuel trying to lean it out??
Old Jan 4, 2002 | 04:21 PM
JAS BLK 98 TA A4's Avatar
That's the beauty of the MAF system, adjusts to weather changes rapidly. <img src="gr_images/icons/wink.gif" border="0">
Old Jan 5, 2002 | 12:06 AM
Ben99Z28's Avatar
get a MAFT to tune it. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Jan 5, 2002 | 12:36 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a bigger aftermarket intank, and see 60 psi at idle.
I recently had to go -10 up to -15% on the base with the MAF T the car was loading up.
Old Jan 5, 2002 | 12:51 AM
Ragtop 99's Avatar
cold idle or warm idle?
How did you get your cruise LTrims to zero? programming, MAFT, or luck?
Old Jan 6, 2003 | 03:48 PM
MECHAM's Avatar
figure it out?
Old Jan 6, 2003 | 03:55 PM
Nickn20's Avatar
weird that it is doing it with a stock descreened maft.... I like my Ltrims slightly negative they drop right to 0 at part throttle just like you observe, if they were postive the numbers bounce around a little, and could possibly skew your A/F ratio at WOT.
Old Apr 4, 2006 | 02:51 PM
scrmnws6's Avatar
I use the darkside. Mainly because it blends in perfectly with the other screens I use at work. This way if my boss or supervisor are walking by, I am one click away from looking like I am working. And if I do not click fast enough on the other screen, they usually connot differentiate just by glancing at my monitor.
Old Apr 4, 2006 | 03:17 PM
Zick's Avatar
And holy old post batman.
Old Jun 2, 2006 | 12:23 PM
Sgt. Spuds's Avatar
Shirley Temple Drinker
its funny that I just seen this thread, I was looking at a threads url, changed the number to 1 and hit enter lol, and low and behold this threads already been dug up this year? lol
Old Nov 25, 2009 | 04:20 PM
913MOTOR's Avatar
Lafayette,la
Old Nov 25, 2009 | 04:24 PM
Damian's Avatar
LSX Mechanic
Originally Posted by 913MOTOR
Lafayette,la
Wow dude. Not only did you reply to the wrong thread, you brought one up from 8 years ago.
Old Dec 26, 2009 | 07:22 PM
black00ssFL's Avatar
Originally Posted by Beaflag VonRathburg
I am going to be ordering my MWCP 9 at the end of next month. I just need to save a little extra money to get new wheels and tires at the same time.
I am sorry to beat a dead horse, but you have the worst looking under carriage I've ever seen. With the lift I'd spray a **** ton of degreaser, let it sit, and then blast it with a pressure washer. I'd do that until it comes clean. Possibly hit it with an orbit sander to get the rest off. Spray it with rattle can primer or your gun and paint it. With all of those nice parts you are putting under there you should be proud to show them off without people constantly asking you about why your car is so dirty.
I probably will soon. I only had a limited time on the lift since my friend is movng ot of that building the end of the month. Here were too many things arond the lift that can't get wet too. But I just bought the lift from him since it won't fit in his new place. I'm moving it into a bigger shop that me and a few other friends are renting that will be dedicated to working on our cars. When that's up and rnning and spray her down.
Old Dec 26, 2009 | 07:38 PM
I have no idea why my reply went here. I've never even read this thread!
