Stalled+cam ls1's suck
Old Oct 10, 2008 | 07:59 PM
01SuperSport's Avatar
Default Stalled+cam ls1's suck
Ok I was kidding about the title but was just wondering if anyone had an upgraded cam in a non stalled a4 car. Read the sticky that said any cam upgrade should be done after a stall but I really don't want to stall my car. Just want that nice chopping sound Was thinking about the TR230/224-111. Website says that it just needs a tune. Anyone?
Old Oct 10, 2008 | 08:01 PM
Reject's Avatar
you'll need one, it gets to pushing the brakes some and isnt really all that fun after a while. that and your not getting into the cam's sweet spot up higher with having that stock stall slow your revs all the way to the top
Old Oct 10, 2008 | 08:29 PM
tatasta's Avatar
Default Pull 'em up
Get the stall. Cams have a great reputation so people will dive into their engine where there are a million ways to **** something up but the "Big" gain is worth the risk.
Stalls have a shitty reputation but are simply REQUIRED to support your cam. The install is way quicker and less technical than a cam's. This isn't high school in the 70s where your buddy put a 5500 converter behind his old 350 and couldn't figure out why he launched like a turd.
Same goddamn ? over and over!
1 Choose the right cam for YOU
2 Spec the right stall
3 Install them both
4 Get a tune
5
Or...... drive a dog. And quit asking!
Old Oct 10, 2008 | 08:45 PM
DKITCHEN's Avatar
You'll need the stall to make the car drive close to how it did before the cam. I put a Circle D 3000 stall in my CETA when pre-cam and picked up 4 tenths in the quarter mile and got used to the stall on the street in a day or two. After the 226 cam, the car doesn't even feel stalled anymore but drives just like it did stock. Prob should have gone 3600 but the car is a DD and drives great now anyway. I'll go 3600 when the tranny goes
blown03mustang's Avatar
your gonna need a stall....might as well do it right the first time
Old Oct 10, 2008 | 11:01 PM
TXZ28LS1's Avatar
dont even think bout doing a cam before a stall!! if u have to do the stall first!! these guy arent lying when a stall really wakes up the car.
Old Oct 11, 2008 | 02:02 AM
I kind of don't really want a stall because I might do an a4 to m6 swap in the future. Guess a nitrous kit is my next mod
Old Oct 11, 2008 | 02:13 AM
00pooterSS's Avatar
If you stay auto get a stall, a GOOD efficient stall, and you WILL NOT regret it.
My yank 3400 is nice and tight at low throttle and my max fuel mileage loss so far is maybe 20 miles per tank. About 1 gallon of gas depending if I am doing more highway or street.
Old Oct 11, 2008 | 02:34 AM
LIL SS's Avatar
Moderator
For quite a while I was running an XER Based 223/228 106/106 in a 347ci backed with a stock verter 4L80E, 3.73's and 26" tall tire. Power brakes and power steering. This was in a 3,900lb 63 pick up. Local bolt on F-body's might have gated me a little due to the stall in the truck, but mph I was chasing them down.
Would a stall of helped. Hell yah, but can you run a cam with out a stall, yes.
Old Oct 11, 2008 | 02:47 AM
00pooterSS's Avatar
Good info, Cool truck dude.
oh and I assume you didnt pull that 1.669 60ft on a stock stall did you.
Old Oct 11, 2008 | 03:11 AM
WhiteRhino's Avatar
If you dd your car. You won't be happy very long without a stall with any decent sized cam. Like others said, unless you're going to do a m6 swap. Get a stall. It's probably one of the best mods for an a4. Even if all else was bone stock.
Old Oct 11, 2008 | 03:12 AM
lemons12's Avatar
just get a small stall.. something like a 2800-3200 then get something like a f13 cam and an ls6 intake w/ full exhaust.... that wont be the best setup, but it wont be the worst..
BTW, nice sig.. haha
Old Oct 11, 2008 | 03:26 AM
00pooterSS's Avatar
Definately, thats where I am now, pretty much stock with a stall, very noticable.
Good suggestion by Lemons12 on the setup cheap and effective
OP is there a reason you are looking at a reverse split cam? And that 111 will make it chop hard but be unfriendly to a stock stall even more, the 111 is not the only factor in the chop the more duration you have the more overlap you have that causes the chop, the LSA does also, and 111 is pretty narrow, you just need to know what your getting into with that cam, and that is a bad choice for a stock stall.
Old Oct 11, 2008 | 07:45 AM
Chrome355z's Avatar
Stock converter i'd go no more then a 224/224 on a 114, and that's really pushing it.
Old Oct 11, 2008 | 08:12 AM
firefighter813x's Avatar
I had a more agressive Vigilante 3600 converter and just swapped it for the Vigilante 3200. I really like it a lot. (DD) Especially with a cam like mine (230/227) the converter wakes the car up even with the 3.23 gears.
Old Oct 11, 2008 | 12:39 PM
00pooterSS's Avatar
Your liking the 3200 more? From what I understand the VIG's are a bit loose in comparison, I can tell you my Yank 34 is real tight, almost a little too tight. But it helps with the street MPG.
Old Oct 11, 2008 | 12:56 PM
lemons12's Avatar
my vig is about spot on.. although its a 4k....
Old Oct 11, 2008 | 01:07 PM
00pooterSS's Avatar
**** maybe vigs are on and yanks are tight I dunno, I drove a car the other cay that was a "yank" 4K and it was sloppy as pig slit, very inefficient on the low end, but my comparison may not be a proper one either, I have the Pro Yank, it is made for up 1000 rwhp cars so it may require more power to get it to slip to its rated stall???
Its hard to say, not enough stalled cars running around I can spend time in and feel the differences, let alone if the people would let me drive them, thats the shitty part about stalls, so many out there with different storys it makes them hard to pick, but im with you buy a big name and you will at least knock out a better part of the issues with stalls from the start.
Old Oct 11, 2008 | 01:20 PM
lemons12's Avatar
+1 on the big name, i got a friend that lost 5 mph with one stall.... cant remember the brand name.. switch to a better stall and it went back to what it was and then +2 more..
Old Oct 11, 2008 | 01:23 PM
Detoxx03's Avatar
Dude you are gonna need a stall. I drove my car for a couple of days with no stall because ups didn't deliver to the right address and man was it a pain in the *** to drive. Do yourself a favor and listen to us when we tell you to get a stall. It doesn't have to be a big one but get one
