grinding front cover for slp oil pump and double roller?
They show you might have to grind cover in instructions for the slp oil pump and double roller combo. Did you have to or not..did you have to grind the pump?
Also some people think don't read the instructions.If you use the slp pump you don't need to use spacers .This might be why some people say they had to grind and others think didn't.
I have the pump and the double roller, I did not use the spacers but what I did was pit a thin layer of grease on the timing chain links that face the cover and then install the covey with you old gasket. I had one spot in the middle area of the cover that was very close and transfered grease to the inside of the cover. I only had to do minimal grinding to get it to clear.
