New cam or FAST 92???? Help me decide!!!
The short story:
-Should I get the Torquer V3 over my TR224 OR the FAST 92mm!??
The long story:
The only thing I know is thats a Thunder Racing cam peaking at 6200rpm with the LS6 intake with good power across the band. BUT, the car's idle is set at 1200rpm and it needs to be rev at 2000 to get a clean launch without surging or bugging(not sure if its clutch related). Pretty sure it might be the TR224.
So, its in the car since 5-7years I'd say. Maybe its time to freshen up the valvetrain and get one of the latest cam outhere. I'm really thinking about the Torquer V3. I should get all I need to do the swap for under 1000$. The car is not a DD, not a track car, just a highway terror
. Honestly, I like to cruise in sixth at 1800-2000rpm and do nice and long road trips
Rarely going over 2500rpm in town and I love my 3.42
OR, get the mighty FAST92mm, port it myself and hope its going to give me the famous 25rwhp for the 1200$++...
OR I just shut up and wait for the 9inch
go something bigger like 23x/24x with around 600 lift.
fast 92 is only worth it on bigger cams not much gain on smaller ones.. maybe 10-15rwhp instead of 25-30rwhp on a more aggressive setup.
I think the Torquer V3 is nice at 231/234 643/595..Keep in mind that I will not change the 3.42. Or go big or go home with the MS4 with the 3.42
go with that MS4 you will see impressive results!
torquer gonna give you same drivablity with less power trust me. Just get a good TUNER!
About the gasket, I put a Fel-Pro because I did one head only(one leaking). Should have put the .40, but I was too lazy to do both..Anyway, I'm not sure about the MS4 because of what I do with the car and the gear. I will need to go back to TTP to get it retune..
What I fear the most is changing the cam and not seeing good hp increase, so I need to go really big I think.
Your TR224 should not be idling at 1200 rpm.
Listen.. I am running gear as well trust me it wont be a problem. You can upgrade the rear gear later like I plan to in a year maybe. There is TONS of mid range in my cam and I have no problem trottin around town.
I am running stock gasket too no biggie.
ehh..
ehh..
the 224 you have aint going to help your 408 at all.
now if you want a healthy bottom and thats what you want then you need a whole differnt cam. I dont know why you would want that. My car doesnt feel dead down low at all. 2nd gear rolls I can get on it at 1500 and at 3k it will rip tires to redline! very responsive for me and anything more would just be worse. plenty of down low middle and top.
