need cam help
Old Oct 14, 2008 | 08:29 PM
chris3113's Avatar
Default need cam help
i am putting a comp cam 224/230 .591 lift 112 lsa cam in my car. can i run stock ls1 timing chain? if not where can i fing single roller ls2 timing chain i cant find them anywhere
Old Oct 14, 2008 | 10:43 PM
conan's Avatar
http://www.texas-speed.com/shop/cate...MID=1&catid=53
Bought a lot from tsp great customer great company to deal with.
Old Oct 15, 2008 | 03:06 PM
Raise's Avatar
It is very cheap insurance to upgrade, at least to the LS2 chain which can be had for under $40. Check out Scoggin Dickey to the right 1-800-456-0211.They always have great prices and seem to keep good stock. The only difference between the install is...if you keep your stock chain, which many people have done, you can skip the step of removing your oil pump. But its really not that bad. The biggest bitch about that step is religning the pump on the gear while sliding the pick up tube in without pinching the o-ring. My advice...at least put an LS2 chain on. Its a single chain, but if you look at them side by side, its definitely a lot thicker and stronger than the LS1 chain. In fact, I dont even think you can buy the LS1 chain anymore, as the LS2 chain has taken its place.
Old Oct 15, 2008 | 03:35 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Thanks for the referral, Conan! Like he said, we keep all of those chains and chain-sets in stock and can answer any technical questions you might have about these engines/products! We'd be glad to help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 15, 2008 | 04:06 PM
chris3113's Avatar
thanks for the help! bought one yesterday from mph motorsports
Old Oct 15, 2008 | 06:00 PM
conan's Avatar
I've had nothing but good experiences from you guys.
Old Oct 16, 2008 | 04:40 AM
chrs1313's Avatar
whats up with your name
Old Oct 16, 2008 | 08:58 AM
Jason 98 TA's Avatar
We stock the LS2 chain & ported oil pumps for camshaft installs. Both of these items are inexpensive add ons that provide peace of mind!!
http://www.texas-speed.com/shop/item...d=620&catid=53
http://www.texas-speed.com/shop/item...d=151&catid=36
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
