Help!!
Old Oct 14, 2008 | 09:15 PM
00 black ss's Avatar
Default Help!!
i have a 2000 ss. Check engine light came on. the car was running about 200-210 degrees and only running for about 15 minutes. i dont think this is normal. kind of worried bc i only had the car for 3 weeks. what should i do?
Old Oct 14, 2008 | 09:50 PM
ABQ99TA's Avatar
Go to a local parts store (autozone) or something like that have them pull the code for free and post back with the code. The temp thing should be OK. 200-210 is normal
Old Oct 14, 2008 | 10:37 PM
conan's Avatar
What he said ^^^ get the codes read. Probly not a big deal... and if you never have had a all aluminum engine it doesn't take long to get some heat in them.
Old Oct 15, 2008 | 03:18 PM
just got home from autozone. i have a blown cat. how much should it be to fix a cat? i was wondering if a catted y pipe will bolt up to stock exhaust manifolds? if not i mite be looking at some headers and a catted y pipe
Old Oct 15, 2008 | 03:33 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
What's the number of that code? Every time a code says "catalyst" or anything similar, they'll tell you it's a bad catalytic converter. MANY times though it is not. Get the code NUMBER and we can help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 15, 2008 | 03:46 PM
did not get the number. i am going to go back today or tommorow and get the number so you guys can help me
