valve spring comparison
Old Oct 15, 2008 | 10:06 AM
silverz28camaro's Avatar
Default valve spring comparison
right now i have a 224/227 .563 .569 114 cam with the patriot gold dual springs.
i was thinking "maybe they are over kill with my cam"
i see the beehive springs are good for some 650 lift and they are single compared to the double.
i was wanting to know if the single springs offer quicker revs and more response
due to the lesser spring pressure.
i was also wanting to bump up the car while i'm in there to maybe a 230 .590 112 cam
any input appreciated
Old Oct 15, 2008 | 05:12 PM
un17real's Avatar
sure if u want too put the time into it then theres no reason why u shoulden't go 2 a custom grind like myself with putting 2 cams in within weeks of each other and happy now. i have the same dual springs and i like the security of having an extra spring so if i decide too open up the 3 1/2 in race headers . also a4/m6 ??
Old Oct 15, 2008 | 05:43 PM
a4 3600 stall
11.569 117 1.599 60'
Old Oct 15, 2008 | 08:44 PM
KCS's Avatar
KCS
Moderator
Beehives. Better control for the pressure and lighter components. Just match it properly to the cam (ie adequate spring pressure and distance from coilbind) and you're good to go. I like PSI's stuff alot.
Old Oct 16, 2008 | 09:27 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Either valve spring will support your camshaft without any issues. We've gone 50k+ miles on PRC spring kits with 228R camshaft. I don't expect you to get near that kind of life out of a single beehive.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Oct 16, 2008 | 11:25 AM
Raise's Avatar
I wouldnt go through the effort just to change springs. If you decide to go with a different cam, then go for it. But just for springs, nah. It is true, the single springs will better control the valvetrain. As far as the benefits of dual springs 1) the inner spring certainly adds to the durability of the outer spring 2) its nice to know if one breaks, you have back up insurance. That being said, if you match your cam and springs properly, you shouldnt have to worry about it
Old Oct 16, 2008 | 08:22 PM
KCS's Avatar
KCS
Moderator
Why is a beehive less durable/not last as long?
It seems with less weight to control, less friction/heat (from coils rubbing), and less spring pressure requirements (also less friction and heat) that the beehive would last longer. OEM's seem to agree too.
