stock internal hp limit!
Old Oct 17, 2008 | 12:07 AM
silverz28camaro's Avatar
Default stock internal hp limit!
What is the max rpm limit for a stock internal ls1 2000 camaro
I spin it to 6400 now and it seems to be taking the punishment.
My plan is to get a bigger cam with 6800 rpm power band and i need to know if the stock internals are up to the task.
Right now i have a 224 .560 114 cam, ls6 heads( home ported),full bolt-ons,dual valve springs,and a high flow high pressure oil pump
Am i gonna have to buy all forged internals.
Old Oct 17, 2008 | 12:13 AM
ABQ99TA's Avatar
If it is a 2000 I wouldn't take it past 6500 the rod bolts are the weak link. I have a few times but I try to avoid it and shift aroud 64-6500. What are you really going to gain from 2-300 rpm its not worth a motor.
Old Oct 17, 2008 | 12:16 AM
WSsick's Avatar
I bet you could spin it to like 8000 if you really wanted too. haha j/k.
but so ABQ i think hit it on the head, the cam will give you more of a gain than just spinning it higher. and great point on the rod bolt thing
