will i have to fly cut with this set up?
i have a trickflow cam, 228/230 cut on a 112 with a 585 lift.
i wantin to use the texas speed 5.3 heads. i can turn bolts and put these on and stuff like that. but when it comes to workin numbers and gettin everything to work together i fail lol.
also is that cam big enough for these heads? this car will b a street car mainly..
http://www.texas-speed.com/shop/item...id=84&catid=20
also, i am runnin 7400 PR now, wat size will i need on these heads?
It'll clear fine and make for a nice DD 7.4 pr's will work just make sure they are chromemoly.
LS1Tech Premium Sponsor
That combo will work fine. The 7.400" pushrods will be really close & we can probably even mill the Stage 2.5s just a little bit for extra compression!
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
