Quick question *driving myself crazy*
Old Oct 22, 2008 | 10:08 PM
mr.fast's Avatar
Default Quick question *driving myself crazy*
With these heads and cam what max cid. stroker would yall recommend??
RPM stage 3 LS6 Heads
2.02/1.60 valves, been ported on both intake and exhaust side, milled .030
Crane dual springs good to .650 lift
RPM 4 .595/.601 232/236 114lsa. cam
p.s. 42lb inj.
Old Oct 22, 2008 | 11:26 PM
mr.fast's Avatar
bump...
Old Oct 23, 2008 | 07:59 AM
willyfastz's Avatar
Restricted User
Are you saying your going to build a new engine and need it to match the heads and cam you allready have?
Old Oct 23, 2008 | 10:44 AM
mr.fast's Avatar
Will this head/cam combo work well with a 402 or 408??
Old Oct 23, 2008 | 12:08 PM
Sleeping00Z28's Avatar
More duration will help a ton. Big cubes need more duration.
Old Oct 23, 2008 | 02:32 PM
toneloc60's Avatar
So, you're going to attempt to build an engine around heads and a cam just cuz you already have those items? Not smart.
Old Oct 23, 2008 | 03:04 PM
mr.fast's Avatar
No, I was just expressing my thoughts.
If I build an engine it will be a TS 454
Old Oct 23, 2008 | 03:10 PM
toneloc60's Avatar
At no point did you express a thought. You asked a question.
Old Oct 23, 2008 | 08:24 PM
racer7088's Avatar
p.s. 42lb inj.
Bigger is better although it will mostly move the power down in rpm if you do nothing but make the engine bigger. You could use a larger cam or heads or both of course.
Old Oct 23, 2008 | 10:19 PM
mr.fast's Avatar
