How Much Does it Cost to Go Solid Roller?
At what point does it does it become cost effect to go solid? Even if it cost a little more the advantages might make it worthwhile. Especially if the lsx intake is tuned for high rpms.
Bret
Bret
Adjustable rockers, pushrods, springs / retainers / locks, lifters, and cam would be the minimum hard parts. Then add on machining the heads, having the springs properly set up and measured, opening the pushrod holes (or some grinder time on your own), etc.
Not cheap, but 7500 RPM sure is fun.
Andrew
