Tried and True 6.0L Engine combos???
Old Oct 26, 2008 | 08:21 PM
cabech984's Avatar
Default Tried and True 6.0L Engine combos???
Hi all,
My 1990 Firebird's 3.8L Buick Turbo V6 recently took a poop. I have a 67k mile LQ4 pulled from a 2002 Yukon. I want to put the motor into my Firebird over the winter. Im looking for some proven combos for all around street duty with some good speed in the 1/4 mile as it will be occasionally be driven on the track. The car has a TH400 that Ill be retaining as well as a 3.23 10-bolt from an 01 TA.
What I'd like to see out of the combo is 450+rwhp, 450+rwtq. Im looking for a N/A setup because Im having no luck with the Forced Induction haha!
Any advice on a good build from cam all the way to injectors would be sweet!! Im considering all options! If I need to post anymore info let me know and Ill supply what I can.
Old Oct 26, 2008 | 08:25 PM
Joey316G's Avatar
are you interested in selling the complete buick turbo motor?
Old Oct 26, 2008 | 08:27 PM
cabech984's Avatar
Oh yeah, like everything in this day and age, Id be doing this on a budget lol.
Joey316, you have a pm...
Old Oct 26, 2008 | 08:36 PM
99blancoSS's Avatar
Sent you a pm with some info
Old Oct 27, 2008 | 05:07 PM
m8w6r77's Avatar
i would like to see some of the tried and true combs also for the lq4.
Old Oct 27, 2008 | 05:09 PM
89IROC's Avatar
ditto im building my lq4 too so the more info the better
Old Oct 27, 2008 | 05:28 PM
Hi-Po's Avatar
Wouldnt mind seeing some different angles on the LQ4. Are any shops willing to take your LQ4/9 and fit it with 402/8 components? Thats what I really want to know. If I Could save some money using my block it would be awesome.
Old Oct 27, 2008 | 07:46 PM
ss454327's Avatar
http://www.carcraft.com/projectbuild...ock/index.html
Old Oct 27, 2008 | 08:27 PM
cabech984's Avatar
Definately going Fuel Injection and Head and Cam. That carcraft article is showing 480 flywheel HP with a Hotcam, and single plane intake. Might get a smidge over 400rwhp in the car. Any other ideas?? I see lots of LQ4/9 Budget stuff!!!
Old Oct 27, 2008 | 09:10 PM
jmm98LS1's Avatar
What does "budget" mean to you?
I'm building a 370ci (.030" over lq4) with forged pistons/rods, TSP ported heads and a big custom hydro cam.......shooting for 475+rwhp N/A (625+ on spray) with a $4k max budget. Takes some parts hunting and finding deals.
Old Oct 27, 2008 | 10:17 PM
Clevite Kid's Avatar
Long tube headers, FAST 92 manifold and ported throttle body, AFR225 heads with thin Cometic gaskets, LG G5x3 cam.
This will get you real close to 450 RWHP.
Old Oct 28, 2008 | 04:34 PM
cabech984's Avatar
I wouldnt say I have that much budget. I have to buy parts to swap the engine into a Third gen as well.
Swap Headers: $800
Swap mounts: $85
Fbody Oil Panw/ sump and windage tray: ???
Fbody Accessories: ??? Can I use the 6.0L Alterator, PS Pump and Water pump and just use an Fbody pulley and brackets??
Im sure there are more parts I need as well before I even consider heads, cam and intake as well as injectors!!!
Old Oct 28, 2008 | 05:48 PM
Hi-Po's Avatar
Pretty sure you have to drill and tap a hole for the alternator bracket. Other than that, all acc. will work.
Old Oct 29, 2008 | 10:44 AM
GA95DCMSS's Avatar
The only thing you can used from the truck setup is the alternator. The waterpump pulley is spaced out to far for the F-body accessories. So unless you space out the F-Body brackets and line everything up, it won't work. I'm in the process of spacing mine out as we speak, so I don't have to buy another water pump.
Power steering pump is a different design and won't work with the F-Body bracket, due to it having a built in reservoir.
Old Oct 29, 2008 | 09:32 PM
cabech984's Avatar
good info, thanks!!!
Old Oct 29, 2008 | 09:43 PM
cgslow77's Avatar
i have a 6.0 lq4 also going into a 1977 nova. what kind of improvements / losses will you see with a ls6 intake manifold, headers, slp maf + intake?
Old Nov 1, 2008 | 09:47 AM
cabech984's Avatar
Im thinking of just a budget LS3/L92 Head for now. Would this be a good choice for 450rwhp when mated with a healthy cam, #42lb injectors, the L76 or fast92 intake, LT's and other bolt-ons? Any advice would be swell!!
Old Nov 22, 2008 | 10:45 AM
BadAzzGTA89's Avatar
I am also doing a simular build and would like some more combo info for a possable turbo setup that still has good street manors.
Old Nov 22, 2008 | 11:00 AM
Soul TKR's Avatar
okie dokie... i'll post up again
LQ4 6.0 364
AFR 205's (Milled 59cc)
224R Cam (224/224 .581 114)
BBK 80mm TB
BBK SSI Intake Manifold
BBK LT's
BBK ORY
Magnaflow CB
446/416 Rear Wheel... funny thing is, I'm still on the stock injectors with a great A/F across the board! lol
but those will definitely be my next upgrade... stockers are maxed out...
Old Nov 22, 2008 | 11:06 AM
zx9rgreen's Avatar
Guys I'm building a LQ4 to replace the blown LS1 in my Sonoma. My set-up is going to be the PRC 2.5 heads (5.3) milled .02" with custom cam (thanks to predator-z) 224/236 @111+2, LS6 intake, UD Pulley, swap shorty headers with true 2.5 duals. Motor will also see NOS. I have no HP #s from my old set-up, but it ran 12.9s and 109 so I will use that for the comparison of my new set-up.
I would like to see around 113~115 trap with this new set-up.
