surging
Old Oct 28, 2008 | 05:27 PM
ChevyRyda99LS1's Avatar
Default surging
I just got my head and cam done got a new motor. I'm breaking in I noticed when I dry slow sometimes the car will shift, then rpms drop and then it will start surging for a little bit then mellow out I think its because of the stall I am assuming this is something the tune will fix when I get it on the dyno. Like I said before I am still breaking the new engine in and and have about 500 miles on it and am breaking it in to 1000 before I get it on the dyno. The stall is not that big either 3200 I guess it might just be doing that because its not tuned up yet or would the cam make it surge or what anyone ever had this issue.
Old Oct 28, 2008 | 05:49 PM
snake charmer's Avatar
without a tune the cam will surge . depending on the cam specs some more than others . in an automatic it is is just more noticeable as with a manual .
Old Oct 28, 2008 | 08:17 PM
DaveX's Avatar
If it has the factory tune, I'm surprised it's not much worse. It needs to be tuned for driveability to address street maners. And I wouldn't drive it much at all unless you know where the AFR is.
Old Oct 28, 2008 | 08:56 PM
Black FormulaLs1's Avatar
just what DaveX said...AFR is a MUST
Old Oct 29, 2008 | 10:08 AM
its not the factory tune its a base tune a safe tune just for me to break in the motor but I get the jist of it the tune should iron it out
