Best head and cam package???
. We are not looking to mix and match parts I know that their are plenty of kits what would you guys put on your cars or have done to your cars. dyno # track times ect... AFR 205's milled 59cc work done by LG Motorsports, and LG G5X3... made 433/410 through a stalled 4L60E, and I run 11.9 at the track with street tires...
http://www.texas-speed.com/shop/cate...MID=1&catid=47
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
You can find our most common packages listed here, however we can tailor the package to fit your needs.
Thank you
Regards,
Rick LeBlanc
Livernois Motorsports
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
