Camshaft Discussion part II
Old Aug 21, 2004 | 02:47 PM
  #381
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Well, I am think an 8 tb setup where you can alter runner length at will might be sorta cool.
Old Aug 22, 2004 | 03:35 PM
  #382
CHRISPY's Avatar
Originally Posted by SilverSurfer
True the LSA is a byproduct, but I'm willing to bet that when the cam specs were being decided upon this byproduct was taken into great consideration.
The VALVE events is what is taken into great consideration
Reduction in overlap (For smoother idle) Necessitates an aggressive (lift and ramp rate) small duration lobe.
The LSA is simply a byproduct of that calculation.
Old Aug 22, 2004 | 10:18 PM
  #383
FASTONE's Avatar
J-rod,now you are touching on something new to this thread I 'd like to see discussed in detail,intake runner cross-section area ,lenth and the header diameter,lenth and the collector type and size(4-2-1,HV MERGE.standard type).I have ask about the collector style with NO response and I know it can be answered on here.
Hey Ed at HPE,build a manifold similar to a 2 4 barrel tunnelram with a removable top,then you could make 1\2 spacers to put between the runners and the top(so you could tune),you could still use the single TB on the front.
Old Aug 23, 2004 | 12:46 AM
  #384
2MuchRiceMakesMeSick's Avatar
wow thats some good info
Old Aug 23, 2004 | 09:08 AM
  #385
J-Rod's Avatar
Ed is at FTI.
Erik is at HPE
As for the tunnel Ram, All that would do is adjust plenum volume, not runner length unless you made up some trick spacer that fit runners and had separate openings for each runner.
Anyhow, I guess I was looking at total package. I can start a thread on header and intake tuning if folks want to discuss that. What I was trying to do is perhpas look at what is necessary to tune the intake and the header to compliment the cam or vice versa, and how you calculate optimal values for that.
Old Aug 23, 2004 | 04:59 PM
  #386
FASTONE's Avatar
Your right J-rod I meant Erik at HPE,sorry!!
Old Aug 23, 2004 | 05:04 PM
  #387
FASTONE's Avatar
Thats what I was talking about, a spacer that went between the 8 runners and the bottom of plenium, yes with the 8 holes to match the top of port runners. Lets do the exhaust and intake technical stuff,sounds cam related to me!
Old Aug 23, 2004 | 06:28 PM
  #388
Ben R's Avatar
That would be a good thread. I say go for it!
Old Aug 26, 2004 | 07:34 AM
  #389
J-Rod's Avatar
Ok, so anyone got some formulas for those ?
Old Aug 26, 2004 | 10:34 AM
  #390
-=Merlin=-'s Avatar
Thats definitely an area that needs to be explored J-Rod.
As for formulas, I don't know any off the top of my head but its going to be a function of valve openings and closings at a specific RPM, the frequency will change as RPM increases (duh!). I would think overlap would play a significant part in that as well.
This would be more of a lab experiment IMO. Who's bringing the beers?
Frank
Old Aug 26, 2004 | 12:48 PM
  #391
Cstraub's Avatar
J-rod,
I can calculate it after the camshaft has been figured for a specific combo. Optimum intake lengths, optimum header ID/Primary Length/and collector ID. Most are worried about header sizes seems, but those then spend time with intake lengths do see power gains. Gains are slight but in competition, every edge you can gain is an edge.
Chris
Old Aug 26, 2004 | 01:42 PM
  #392
Ben R's Avatar
Originally Posted by Cstraub
J-rod,
Chris
Care to share the formula's for your calculations?
Old Aug 26, 2004 | 03:41 PM
  #393
-=Merlin=-'s Avatar
J-rod,
Chris
So then would grinding a particular cam for a combo be iterative?
Reason I ask is don't you measure flow through all the components, i.e. from throttlebody to intake valve at different lift points etc, and then grind the cam?
Old Aug 27, 2004 | 09:20 AM
  #394
J-Rod's Avatar
Its a good question Merlin. I was't sure what other folks felt the "order of operation" or "order of importance" was in the cas eof laying this stuff out.
Anyhow, the math I have for headers is:
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
These formulas are from A. Graham Bell’s Performance Tuning in Theory and Practice. For a street engine, the RPM used should be the peak torque RPM. For a race engine, the peak hp RPM should be used. I most tune stuff for "race engine" as that is the way most of them are used.
Old Aug 27, 2004 | 09:24 AM
  #395
MUSTANGEATER's Avatar
It'd be nice to make a post w/ just formula's and how to apply them.
J-rod your box is full
Old Aug 27, 2004 | 10:10 AM
  #396
J-Rod's Avatar
I think I started a thread on thatI will have to see if I can find it.
In the meantime:
Exhaust Systems Tuned Length
Lt = (Eo x Vs) / N
Lt is the tuned length, in inches
Eo is the exhaust-open period, in degrees
Vs is wave speed in feet per second (1700 ft/sec at sea level)
N is crankshaft speed, in RPM
Length of Curved Pipe
L = R x .01745 x Z
L is length
R is radius of the pipe bend
Z is the angle of the bend
Diffuser Proportions
D2 = SQRT( D1^2 x 6.25 )
D2 is the diffuser outlet diameter
D1 is the diffuser inlet diameter
6.25 is the outlet/inlet ratio constant
Baffle Cones
Lr = Le/2
Lr is mean point of the reflection inside the baffle cone
Le is the length of the baffle cone
My box has space now...
Old Aug 27, 2004 | 12:12 PM
  #397
Ed Curtis's Avatar
Talking
I'm not touching THAT line with a ten foot pole...
Ed
Old Aug 27, 2004 | 03:47 PM
  #398
J-Rod's Avatar
Stop touching me....
Old Aug 27, 2004 | 06:50 PM
  #399
XLR8NSS's Avatar
Adkoonerstrator
Did somebody say box?
I apologize in advance J-Rod
Old Aug 27, 2004 | 10:55 PM
  #400
Ed
What about this one?
