question for vettenutts
Did you verify the rivets cleared the heads (fell into a jacket)?
Did you install with the little holes in the front, large passages in the rear?
Did you re-install coolant sensor and rear passenger side plug
I really dont understand #2. I am looking at the gasket and dont know what you mean by larger / smaller holes. I attached a pic of the gasket ,so if you could elaborate, i would appreciate it. Im getting ready to reinstall them with copper gasket sealer and dont want to do it a third time, so any othe tips would be appreciated. thanks
one way will look right, the other the holes wont line up right.
but the picture above is correct. Just remember the corner with three holes (two coolant passages and one bolt hole) goes to the rear of the engine and you'll be fine.
