setting preload with stock rockers?
OK i have Absolute Speed ported heads, with ferra valves and texas duel springs installed.
Using stock LS1 rockers with the Harlem sharp bearing rebuild mod, comp 7.4 (stock length) push rods , stock rocker pedistals,
OK I think the heads have only been cleaned, maybe block sanded, not milled,
so set up should go smooth, but if not how can the stock rockers -lifters be preloaded?
I have Comp R lifters , but i think i am going to pick up a set of the LS7 lifters
The heads you are using, milled or not, valve angle, lifter bleed down, cams base circle, and if the lobes for intake/exhaust are different they might require different lengths.
Easy answer is to measure them, thats the only answer I ever got!
Look for the posts by vetennuts(sp?) just search correct pushrod length and it will come up.
I am going to use the LS7 lifter, LS2 buckets 7.4 comp push rods and stock Rockers with the Harlem sharp bearing mod-rebuild, my heads are ported 241 castings , they have been cleaned and block sanded,
