Heads for stock cam
The 5.3L heads do not have to be milled so much to get the extra compression. They do however sacrifice a few CFM of flow compared to the LS6 heads. They are less expensive though, so that's a nice way to save a few bucks for that LS6 intake manifold!
We offer both the 5.3L and LS6 heads fully CNC ported and would be happy to help you with your combo!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
So my added parts list is growing with:
ARP Head Studs
1.85 rockers*
Valve cover spacer*
Headgasket suitable for nitrous
**** Heads
Remaining on the motor without changing my cam I would like to make a good amount of power, by what nominal factor I cannot say. The rockers to increase lift of the stock cam, great idea I didn't think of. Nice heads will always make power on a motor, hell I might even look into a FAST manifold setup but I would believe that the LS6 would suit me alright. I can't really seem to find any info on a FAST manifold bolted onto a stock LS1 for gains. But with a good intake manifold/possible TB combo and nice flowing heads I will be happy with the output that I get. Remember I am spraying a 150shot on top of it. Its quite possible that I would back off to a 100 shot afterwards though, I don't need to set the world on fire, however I would like to be happy with my car how I build it.
just sayin. even a Z06 cam would do you some real justice IMO, or maybe an old man cam. k i quit. but my vote on heads would be AFR 205s. if your gonna spend 1500 whats a few hundred more? if you search AFR 205s you could fall in love with the idea pretty quickly
i have also wondered about just swapping heads on the stock cam.. aftermarket CNC'd factory castings cost almost the same as a high profile parts cam swap, and im sure with a really good set like the 205s you'd pick up engine efficiency (mpg as well) on top of great throttle response and power. just how my brain is wired anyhow. Is that the AFR head you mentioned? Oh and I'm not all too worried about mpg, I have a work van and an '89 crx for a beater.
