Need Help and i have search everywhere...
Old Nov 4, 2008 | 12:44 AM
onebadredss's Avatar
Default Need Help and i have search everywhere...
i have looked everywhere... and i still can't find anything...
well my friend is buying a Camaro...
and when we looked at it it had a cast iron block... and 706 heads... well i looked up the heads and they are 5.3L heads now did the 5.3L come in cast iron... or aluminum we are trying to see if the block is a 6.0L...
Please anyone Chime in...
Old Nov 4, 2008 | 01:22 AM
jermzz's Avatar
5.3 is cast iron, too. I dunno why someone would drop a 5.3 into a camaro though. Could be a 6.0 with 5.3 heads, but that wouldn't make a whole lot of sense.
Two ways to check. First, you can pull the tranny, and clutch assembly / flywheel, or flex plate if its an auto and look at the back of the motor. The 6.0's have "6.0" stamped into them on the back somewhere i forget what side.
other way would be to pull the oil pan and measure the rod length. 6.098 is the rod length for a 5.3.
i'd personally pull the tranny. its easier.
Old Nov 4, 2008 | 09:31 AM
damn i thought the 6.0L was stamped under the manifold somewhere...
Old Nov 4, 2008 | 10:16 AM
jermzz's Avatar
it might be stamped under the ac pump or behind the alternator / power steering assemby too.
Old Nov 4, 2008 | 10:23 AM
5_02ls1's Avatar
id say its a 5.3 its actually a fairly common swap now....id say the previous owner bvlew the ls and dropped in a low mile 5.3....do a short search....alot on here have done it....they arte cheap and everywhere....ive thought about it myself...
hows it run???
Old Nov 4, 2008 | 11:12 AM
see its loud at idle... but something is wrong with the OPS the gauge don't work... but its a SS and a M6.. hes buying it for 4 g's
Old Nov 4, 2008 | 04:20 PM
ZMONSTER!'s Avatar
Almost definetly a 5.3, hell a 6 liter short block costs almost what hes going to pay for the car total.
5.3 is a good block though, you can have it bored out and make a 346 or 383, as far as that goes its pretty much the same as an LS1 as far as I know
Old Nov 5, 2008 | 01:55 PM
19torch99's Avatar
I'm the guy buying the car. You would assume that it is for sure a 5.3 because why would someone put a 6.0 block and sell it for only 4k? Well......the seller doesn't realize that there is an iron block engine in the car. He bought it from an auction cheap and does not know a whole lot about LSX cars. Holding out hope that it's a 6.0L engine, but perfectly ok with the 5.3L as well.
