Will i need to fly cut
Old Nov 5, 2008 | 11:13 PM
coderedDVSS8TR's Avatar
Default Will i need to fly cut
I have an MS3 and im going to do my head swap this weekend. I already have Cometic MLS stock thickness head gaskets and im pretty sure i wont have to with these. I was wondering if i can go thinner to get a higher CR. So will the PTV be good with .041?
Cylinder heads specs
706 casting
62cc chamber
2.02 int
1.57 exh
Is there any other info that i should put down to get a accurate response? Thanks
Old Nov 6, 2008 | 09:20 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Who worked the heads for you? Unless they are the PRC 5.3L heads specifically set-up for that camshaft, you will have piston to valve clearance issues, even with the stock thickness gasket.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 6, 2008 | 04:17 PM
hi flo engineering out of lakeland florida. stage 3 port job on 706 casting. well that is good to know that i might have issues with PTV even with stock thickness.. looks like a shop will have to take over. Thanks
Old Nov 6, 2008 | 04:20 PM
bad2dbone's Avatar
I use the mahle to fit my stock rods again they were forged out check em out
Old Nov 7, 2008 | 07:39 AM
sedanman's Avatar
With PRC 5.3's set up for a MS3 still be ok with PTV if my MS3 is on a 111 lsa?
Old Nov 7, 2008 | 09:06 AM
You'd want to check the clearance with the 111LSA (always a good idea to check anyway, but this is going to cut down on clearance that is already tight)!
__________________
Old Nov 7, 2008 | 02:09 PM
sedanman's Avatar
How much clearance should I need? I really would hate to order these heads then find out I have to fly cut.
