Pushrod Length Question - Intake/Exhasut measure different...
I came up with 7.269" intake, and 7.244" exhaust. All 4 intake were identical, all 4 exhaust were identical. Then add on preload to those numbers. I tried a few different pushrod lengths and figured out what the preload would be.
Prelaod with 7.350" pushrods:
Intake: 0.081"
Exhaust: 0.106"
Preload with 7.325" pushrods:
Intake: 0.056"
Exhaust: 0.081"
I have a few questions. First, why is the length of the intake and exhaust pushrods different? Second, which length pushrod should I choose? Would it make sense to use a different pushrod length on the intake and exhaust? If I was shooting for 0.080" preload it would seem as if that would be the right decision. I would appreciate any pros on the subject to shed some light.
A little info on my setup: LS1 with stock bottom end (pistons flycut with Lindy tool), PRC stg. 2.5 5.3l heads with 59cc chambers, MS4 cam, LS7 lifters, stock rockers. Need any more info please ask.
I could go with 0.081" preload and use 7.350" on the intake and a 7.325" on the exhaust.
Or I could go with 0.056" preload and use 7.325" on the intake and 7.300" on the exhaust.
What is the overall consensus?
ZMonster: GM sets them up with quite a bit more preload than .010"....closer to .100" in most cases!
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
