oil pressure high at idle
Old Nov 8, 2008 | 06:13 PM
chetmo's Avatar
Default oil pressure high at idle
setup; H/C forged 347
oil pressure is around 60 at rough idle (just started for first time) around 2k rpms.
just thought this seems a little high.
oil; regular conventional castrol 5w-30 w/ a fram oil filter
Old Nov 8, 2008 | 06:19 PM
Shawn MacAnanny's Avatar
Did you add a melling high volume pump? I have an LPE high volume high pressure pump and i get 75psi at a cold idle of 700rpms and pegs my autometer gauge at 100psi by 2000rpm cold. You're not going to hurt anything.
Old Nov 8, 2008 | 06:22 PM
chetmo's Avatar
yes thats the pump I have. melling HV
Old Nov 8, 2008 | 06:36 PM
Well then i would say thats normal.
Old Nov 8, 2008 | 07:05 PM
383hatch's Avatar
My stocker pushes about that much on startup. Once it warms up it will come down to 40 PSI at idle, 60 at cruise.
Old Nov 8, 2008 | 07:15 PM
Goldfinger911's Avatar
Thats normal for 2k rpm. My ported Z06 oil pump pushes 60psi cold at 1000rpm and 45psi warm.
Old Nov 9, 2008 | 01:59 AM
GM WORLD CLASS's Avatar
as long as your pressure relief is operating as designed then no problem. my car has 123,000 m and runs at 50 at idle. runs at like 65 or 70 at cruise.
Old Nov 9, 2008 | 06:39 PM
VTC_WS6's Avatar
My ported LS6 pump sees about 70psi cold, seems to be comparible.
Old Nov 9, 2008 | 11:00 PM
chetmo's Avatar
started car this morning, it was around 75 :WOAH: temp was around 45-50* it warmed up, and eased up a bit.
