best head?
Old Nov 12, 2008 | 06:43 PM
trenth48's Avatar
Default best head?
I have a 99 6.0 with iron heads and i'm putting a MS4 cam in it with stock internals otherwise. I would like to raise the compression to help out with the cam. I am wanting to put aluminum heads on it, but can't figure out which casting number would be best?
Old Nov 12, 2008 | 07:02 PM
Grimes's Avatar
what's your budget? that will be a major factor.
Old Nov 12, 2008 | 07:11 PM
trenth48's Avatar
well i can't afford ported heads right now so it would have to be a set of used factory heads for now with a price range up to $500 or so.
Old Nov 12, 2008 | 07:16 PM
Grimes's Avatar
cool, well in that case, you can get assembled ls6 heads (casting "243") for about 600 bucks. If that's too much, later ls1 version heads (casting "241") are a little bit cheaper.
since you are going with the ms4, I would definitely go with the 243 heads if you can. Pretty sure you will have to flycut your pistons as well with that cam
Old Nov 12, 2008 | 07:41 PM
trenth48's Avatar
thanks for the info. i've heard the 5.3 heads will raise my compression or will those not be a good choice?
Old Nov 12, 2008 | 08:08 PM
Grimes's Avatar
5.3 heads will raise the comp, but I think stock for stock the ls6 heads flow better. You can always get the ls6 heads milled down a little bit if you want to boost compression.
