Which Cam
Old Nov 14, 2008 | 05:24 PM
vettett15's Avatar
Default Which Cam
Hey Guys,
I recently picked up a tsp combo, ls6 stage 1 heads milled to 59cc and a custom grind 224/228 .590/.595 113+1 cam. Right now in my 98 transam I have stock heads, ls6 intake, ps lt, magna flow catback and a 228/232 .588/.575 LSA 113 MTI G1 cam. Before the ls6 intake it made 376 rwhp. I am wondering if I should just leave the G1 in there or switch out for the custom grind or get another grind. I'm not worried about driveability just looking to make the most power under the curve. Any info is appreciated.
Old Nov 14, 2008 | 09:23 PM
Peetyz's Avatar
ahh hard tellin ive got a 228/230 .588/.592 112+2 custom comp cam and I put down the dyno numbers in my sig and the cam drives great and pulls like stock only way harder all the way up to around 6,500 also i have a ls1 gto which has irs and usually lays down lower numbers than a trans am or camaro i still get over 25 mpg on the highway and can drive in 6th at 40 mph no problem
Old Nov 14, 2008 | 09:30 PM
willyfastz's Avatar
Restricted User
If I had to choose between the two I would leave the one you have in the car in there. Not because it's bigger but because it's a little closer to what would be right.
Old Nov 15, 2008 | 07:18 AM
vettett15's Avatar
I guess the one thing I need to check on is how my dcr will be different. Tsp says with the custom grind ill be at 11.4 static and 8.8 dcr. Which means I'm at the limit of pump gas and that thing should be making good amount of torque. Not sure about PTV clearance with the MTI G1 cam though, anyone?
