Patriot LS6 head updates ??
Thanks
Mike
Mike,
That's almost exactly what I'm doing. I'm going to run the TSP 231/237 (a little smaller than the G5X2) with my LS6 style heads. I got the chambers at around 59cc so I can have about 11.5:1 compression for good NA performance and then I'll be using a 50 or 75hp wet kit to take advantage of the split duration camshaft. I'm installing my heads/cam tonight and Friday.. will dyno on Oct 4 NA and on a little spray.
Jason
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
