LS6 heads on LS1 Block
Old Sep 21, 2003 | 05:25 PM
MedicManWS6's Avatar
Default LS6 heads on LS1 Block
I did not seem to find this question in the search, so Does anyone know if I can take stock '02 LS6 heads and direct bolt them to my '01 LS1 block. I know I have the LS6 intake manifold so the intake runners should meet up right??
Old Sep 21, 2003 | 05:35 PM
TVWilkes's Avatar
Default Re: LS6 heads on LS1 Block
Yes,it will bolt to the ls1 block.
Old Sep 21, 2003 | 05:41 PM
so do you think there will be much gain from this or waste of time?
Old Sep 21, 2003 | 06:16 PM
Z-Rated's Avatar
If you port them yes, they tend to give 10-15 more hp over their LS1 conterpart. are you going to get them ported or are you talking about stock heads? either way you will gain hp
Old Sep 21, 2003 | 06:30 PM
I will most likely get them ported...also any pcm problems with running these heads in the LS1 and do you think the Hot cam would really open up with these heads on the car??
Old Sep 21, 2003 | 06:44 PM
DaleMX's Avatar
What year of LS6 heads are you getting? I believe the newer ones have longer valves and will require a different pushrod. I think that the Scoggins Dickie site (SDPC is a sponser) has info on what year heads have the longer valves.
Old Sep 21, 2003 | 09:24 PM
rickws6's Avatar
I bolted the LS6 heads to my LS1, no problems whatsoever. They're worth about 10 - 15hp over the LS1 heads
Old Sep 22, 2003 | 06:52 PM
Spellbound's Avatar
Yes, they bolt right up. I seemed to notice the power up top though.
