Signs of a cracked head??
So we pressurized the system and began removing one spark plug at a time. Nothing, the pressure tester didnt move from 18psi. Upon inspection of each plug, you could tell that all cylinders were a little fat except #3. that plug was clean. With an odd residue on it.
The one thing we did notice though was the the radiator cap that is supposed to be rated at 18psi would only hit 13psi and then start dropping.
I doubt the cap is causing the problem. What concerns me is that the nice (and expensive) MTI Stage 2 LS6 heads may have developed a crack. OR a couple hairline cracks in the block. I would rather have the block go than the heads.
anyone have some insight as to a possible head problem?
I am going to hook the pressure tester to the radiator tonight and fire it up and see if the pressure goes through the roof. That would indicate a bad block. But I dont know if it would do the same for a bad head.
As far as a compression test. What would be the ideal numbers to see when doing that?
Another thing I just thought of, have you checked the engine oil lately??? Perhaps the coolant is getting passed into the crankcase from a bad crossover pipe or something??? I haven't had a look at the insides of a LS1 before so I'm kinda taking a stab at is that I know on all the older V8 motors have coolant passages in the heads and intake manifold and such. If the crossover pipe is leaking someplace perhaps the coolant could bleed into the crankcase. Again these are just ideas. Hopefully like I said before it is just something stupid.
Speaking of air pockets. Just about 1 week prior to the problem I replaced my knock sensors. And in doing that you have to take off the intake. do you think that I could have got a pocket big enough when I unattached the TB lines to have caused this problem? But that still wouldnt exlain why I could smell coolant in the exausht. But after I put water in the radiator the smell went away and never came back
Now before you go nuts, check the obvious. I know at least one guy who thought he had blown a headgasket when he just had a leaky/ bad hose.
Now if you smell it in the exhaust, maybe you are smelling it dripping on your exhaust and it is burning on the primaries... You have to check.
When I had some blown head gaskets, it would start out very minor, I would lose a pint or so. After two weeks it would be up to 2 quarts. But by then you would see and smell the coolant burning in the exhaust.
Replace the radiator cap if it looks like the plunger is getting gunked up. It might be sticking open.
Look for dexcool blowing out the res ventilation cap too. This could be caused by a head gasket problem with the exhaust gas getting in the coolant system which can over pressurize and defeat the radiator cap too. Exess fluid will blow out of the res containter top. You'll be looking for wet spot marks on the battery and the shock mount area. It will typically dry up at speed so look for mark and not neccessarily wet spots. A quick test for this is to top off the fluid. Start her up get her to temp and make a few WOT runs. Then pull over and check for fluid around the res container area.
Take off the Oil cap... do you see any moisture on it? Does it have a greenish milky slime? Again, coolant getting loose from a head gasket leak.
Pull the head cover to TB hose. Shake it... does milky oil slime come out of there?
The white smoke that you would normally expect may not show in areas that are warm enough and dry enough when you first start the car.
As strange as some of these may sound, I've seen all of them in my previous three sets of head gaskets which include fel pro and cometics.
Rick
The res tank is full when the night before the incedent it was empty. But it never got to the point where it was blowing out of the top of the cap. But it is FULL there even might be enough in there to make up for the amount that is missing in the radiator itself. But looking at the coolant that is in the radiator, its clean as a whistle.
I am going to trty blowing compressed air into the cylinder and see if I get any bubbles in the radiator.
I pulled the intake and saw that intake port very clean.On the valve there was a puddle of coolant.
I could smell the coolant burning off, I could see the level was dropping, and feared it was the head gasket. However, just like you, the dipstick was clean etc. It might be worth a look.
