Dyno tomorrow
Old Nov 21, 2008 | 03:02 PM
ChevyRyda99LS1's Avatar
Default Dyno tomorrow
I dyno tune tomorrow what you guys think I will put down with the setup in my sig hoping for 400.
Old Nov 21, 2008 | 03:09 PM
toothdoc's Avatar
I would guess 410rwhp/380rwtq.
Old Nov 21, 2008 | 03:57 PM
Detoxx03's Avatar
411rwhp/381rwtq
Old Nov 21, 2008 | 04:01 PM
TXZ28LS1's Avatar
412/382 is my guess...
Old Nov 21, 2008 | 04:40 PM
I'm a post the results when I get back tomorrow from the dyno
Old Nov 21, 2008 | 05:04 PM
KMS.1320's Avatar
How monster is the monster stall in your sig? and what brand? will this dyno be locked or unlocked?
Old Nov 21, 2008 | 05:10 PM
Monster is the brand of stall its a 3200 nothing to huge its my DD My tuner is telling me he is going to get it to a good bit over 400, last time I got on the dyno it put down 370 rwp thats after a piston broke and only 4 degress of timing over stock and with the 30lb summit injectors. So 370 with a broken piston and that on a stingy *** dyno so I figure if all goes well with the new built motor and bigger injectors it should shoot a cool bit over 400
Old Nov 21, 2008 | 05:47 PM
2001z's Avatar
since your an auto i wouldnt worry about dyno numbers i would get a good tune then hit the track and see what she does.
Old Nov 21, 2008 | 07:09 PM
KMS.1320's Avatar
Don't really see a "good bit" over 400 through an A4 with ported 853's and a medium size cam, but with the convertor locked, I'd be happy with 400-410
Old Nov 21, 2008 | 09:37 PM
VIPERBLUELX's Avatar
what kind of race pistons did molly put in and what's the difference between a race piston and street piston?
Old Nov 21, 2008 | 09:39 PM
SmurfLSX's Avatar
locked a4 should be 390ish. 228 is a small cam
Old Nov 22, 2008 | 01:51 AM
Detoxx03's Avatar
Small compared to what a trex or ms4? 228 is not a big cam but definitely not small.
Old Nov 23, 2008 | 09:20 PM
SmurfLSX's Avatar
i saw a 232 cam go 410 through an m6. 228 is a small cam .
Old Nov 23, 2008 | 09:39 PM
toothdoc's Avatar
228 is what I have in my car. Look at my numbers through the stock heads.
Old Nov 23, 2008 | 09:50 PM
johnLs1camaro's Avatar
sometimes setups work better with small cams, bigger isnt always better!!!
Old Nov 23, 2008 | 10:23 PM
results delayed couldn't get fully tuned mass air sensor failed got to get a new one it put down 369rwp with stock timing but then it keep going lean car runs like **** now until I get the new maf
Old Nov 24, 2008 | 01:16 AM
Detoxx03's Avatar
We have identical numbers with a 228 cam and stock heads and I have a stall
Old Nov 24, 2008 | 10:37 AM
firefighter813x's Avatar
Don't you also have a ported FAST??? That makes things a little different...
Old Nov 24, 2008 | 02:03 PM
Detoxx03's Avatar
Yeah I understand that but how much of a difference over a 78mm fast? Can't be much. Either way the op should be at 400 or a little over.
Old Nov 24, 2008 | 02:19 PM
coderedDVSS8TR's Avatar
Whats good Will? So you got that screen for your maf now? i talked to dirty and they could have tuned your car speed density with out the maf. i dont know too much about it but it made sense since there are alot of turbo cars running without mafs. but your car should go over 400 for sure
