Do I have everything for cam swap?
Old Nov 23, 2008 | 10:07 AM
99LSS1's Avatar
Originally Posted by camz28arro
I decided just to put a cam in my auto 2002 z28 instead of selling it and getting a m6 to put over 400whp so I don't have to bother selling my car and finding another. Do I have everything listed I would need or any other parts recommended over the listed (besides a recommended different cam) Thanks
2002 a4 z28 48,100miles
Ls2 timing chain
Tr224/224 .563 .563 114 cam
Ti retainers if there is any gain with a 6300/6400 redline
Gm gasket set and balancer bolt
ASP belts and underdrive pulley
shorties (any recommended?)
GM header gaskets
vettedoctors dyno tune
thunderracing 7.400 pushrods
value stem seals
dual patriot gold springs (would appreciate recommendations here mostly)
What idle speed should a tr224 be set at also and do you think it's worth 55rwhp. Thanks.
It does not mention if you have a higher stall converter? This really is a must on a cammed A-4. That is a good choice for a stocked head Ls1. Had that Cam in mine for a good 2 years and ran low 12's with a TCI 3500. Ran low 11's with a 1oo shot of N2O.
Old Nov 23, 2008 | 11:25 AM
Hi-Po's Avatar
What tooling do you guys use for the dual spring kit?
Old Nov 23, 2008 | 01:49 PM
94'BLKBRD's Avatar
http://cgi.ebay.com/ebaymotors/LS1-L...mZ190207738568
Old Nov 23, 2008 | 11:18 PM
camz28arro's Avatar
Do I really need a higher stall to run that cam or the stock 1700 should be fine? because I just ordered everything for $626 besides the springs and coated catted mac mids.
Old Nov 23, 2008 | 11:22 PM
ultraz's Avatar
not required......... but why not throw another 500$ to give you as much gain in the 1/4 mile as the cam itself....?
Old Nov 24, 2008 | 09:48 AM
01ssreda4's Avatar
with a cam AND stall you might as well get ready to buy a sticky set of tires too.
Old Nov 24, 2008 | 10:10 AM
camz28arro's Avatar
..and then pretty soon that would lead to a $3000 moser I'm limiting myself to how much I'm going to spend, I'm just doing this to hold me over for another couple years till I get a different car. All my friends have moved from their shitboxes to Evo9s, STI's, 70 and 72 chevelles, srt-4s, impala ss's with nitrous so I have to widen the lead again. Just ordered the PAC-1218 springs, anyone know a cheap place for MAC mids with catted Y and fittings.
Old Nov 24, 2008 | 01:14 PM
99LSS1's Avatar
I will tell you this. There is not to many Sponsors that would not tell you. Do a stall converter first. It is not all about the performance. It is about driveability as well.
Old Nov 24, 2008 | 04:11 PM
Hi-Po's Avatar
Thanks!
Do you recommend that extra tooling for compression the cylinder to keep the valves up? I had never thought about that . Thanks for that link, im gonna order one.
Edit, have you guys used this tooling with good success and minimal headache?
