WHat cam
Old Nov 24, 2008 | 11:12 PM
domestic disturbance's Avatar
Default WHat cam
i know you guys are like we see these threads all day lol... but here goes nothing... as of right now im just wanting to install a cam only with the valvetrain, i do not want to have to flycut, but i want to go as big as i can without flycutting, I was really looking for the choppiest iddling cam....
mods are
long tubes (RACE)
y pipe with cutout, factory slp catback
ls6 intake
ported tb
slp maf
nx wet 150 shot
spec stage 2
thanks guys, i want this biggest choppiest cam that i can just bolt in
Old Nov 24, 2008 | 11:27 PM
Evans752's Avatar
I do not want to have to flycut, but i want to go as big as i can without flycutting, I was really looking for the choppiest iddling cam....
mods are
long tubes (RACE)
ls6 intake
ported tb
slp maf
nx wet 150 shot
spec stage 2
thanks guys, i want this biggest choppiest cam that i can just bolt in[/QUOTE]
Well you dont want to flycut, and your wanting to go BIG and want THE CHOPPIEST IDLE POSSIBLE, then the TREX is about as big as you could run to my knowledge and is CHOPPY as it gets but will definately need a tune, duel valve springs (Comp Cams 921 or Patriots duels springs) and possibly some injectors. I dont think the Spec stage 2 clutch is enough you have is enough clutch with your 150 HP nitrous in my opinion. Stock springs are JUNK and do good to hold the stock cams in the LS1 motors. Thunder Racing is who sell the cam and all the accessories if you dont know. I hope you get what you want.
Good Luck
Old Nov 24, 2008 | 11:41 PM
willyfastz's Avatar
Restricted User
Do you just want the biggest most radical cam you can run without fly cutting? Or do you want a cam that will actually make the car fast and still have a good sound? If you over cam your car just for the sound your leaving a lot on the table performance wise.
Old Nov 25, 2008 | 08:54 AM
the biggest most radical cam that will actually make the car fast....
thanks
Old Nov 25, 2008 | 09:00 AM
Joey@Tick's Avatar
LS1TECH Sponsor
Check out our Polluter cam, both in the dyno forum and at the following link. It loves the bottle.
http://www.tick-performance.com/cata...ain/#camshafts
