What all is needed?
Old Nov 27, 2008 | 10:32 PM
my01ws6's Avatar
Default What all is needed?
Just wondering what all will I need/want if I install this cam? Do I need valvesprings...etc..etc?
224/228 581/588 112-114lsa
Thanks!!
Old Nov 27, 2008 | 10:35 PM
94'BLKBRD's Avatar
Valvespring kit, pushrods, ls6 or high volume oil pump, ls2 timing chain, gaskets/crank bolt, and spring compressor.
Old Nov 27, 2008 | 10:36 PM
beezer1519's Avatar
springs, retainers, chromoly pushrods, engine assembly lube, locktite red, 3 jaw puller for the balancer, tubes to hold the lifters up... and patience if it doesn't go your way lol... i had to remove the heads cus the lifters wouldn't want to move out of the way...
Old Nov 27, 2008 | 10:39 PM
my01ws6's Avatar
I need all that to install that small of a cam??
Valvesprings....pushrods....oil pump....and timing chain?
Old Nov 27, 2008 | 10:40 PM
94'BLKBRD's Avatar
correct
Old Nov 27, 2008 | 10:43 PM
my01ws6's Avatar
What springs would you recommend? 918s good enough?
Old Nov 27, 2008 | 10:58 PM
94'BLKBRD's Avatar
I would go with Patriot's or PRC's. Can beat the price on their spring kits.
Old Nov 28, 2008 | 12:05 AM
kdavis's Avatar
i would not put 918s on any car i own. I have heard of them breaking on many people.
Old Nov 28, 2008 | 06:05 AM
99blancoSS's Avatar
No..LOL
The valvesprings and pushrods yes, but you dont need an oil pump or a timing chain. The timing chain is a good idea and insurance but not a requirement.
The oil pump people swap out because a couple 98-99's had a failure issue at 100,000 miles way back when... or that was the rumor.
So the timing chain and oil pump are not required at all. Some look at it as cheap insurance.
A spring good to .600 lift is all you need. PAC1218 is what I would go with in this case. Its a direct drop in replacement, no need to change seats or seals. You dont need a dual spring, overkill isnt always a good idea when it comes to valve springs.
I can set you up with a proper package if you like.
Old Nov 28, 2008 | 06:09 AM
BlackTTC6's Avatar
Don't forget HEADERS!!!!!!!!!
Old Nov 29, 2008 | 10:07 AM
my01ws6's Avatar
What size pushrods do I need? 7.4?
Arent the PAC1218 the same as the 918s?
Will the pushrod length still work if I change out the heads? Sorry I dont know alot about the internals of an engine.
These are the two parts I want? (LS6 Oil Pump & LS2 timing chain)
Part numbers...12586482....17801830? Basically just an extra $100?
