Who is running this setup?
Old Nov 30, 2008 | 11:07 PM
1BAD_LS1's Avatar
Restricted User
Default Who is running this setup?
TSP PRC stg 2.5 5.3L / 233-239 Cam Package. Who is running this combination in a A4? Looking to install a VIG 3200 Stall with it. What numbers are you getting with this setup? 1/4, RWHP, RWTQ? DO you Daily Drive it?
Lets see the numbers!
Old Dec 1, 2008 | 08:51 AM
Dragkid1917's Avatar
I got the 233/239 with no heads, I would personally go with a bigger stall... Im upgrading mine from a ss3600 to a PT4000... not saying a 4000 is the best street converter but I think you would best take advantage of the cam's powerband (because its not what TSP rates the power band at) with a little bit of a higher stall.... Just my oppinion on the matter.
Old Dec 1, 2008 | 03:36 PM
99LSS1's Avatar
X2 on the bigger stall. I am running basically the same Cam with some stage 2.5 heads and run a Yank SS 4000. This combo so far has gotten me to the 11.6's N/A. I put dowm a disappointing 375 to the rear with 2 broken valve springs. Haven't Dynoed since replacing them. I will be going with a different Cam this winter. Looking to get more low end and mid range. Looking for a solid 11.5 N/A car.
