Spec me a cam for a high compression 347
Old Dec 1, 2008 | 01:49 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Don't trust your nose (or a tuner's) to dial in your A/F ratio. I understand widebands being out of service, so this is in no way a shot at your tuner BTW. But we hear it all the time that a car smells rich and a customer wants a re-tune. I assume you're running off-road pipes. It's going to smell gaseous with the overlap you're running and no cats!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 1, 2008 | 01:55 PM
ZFSix's Avatar
Well, it definately does.
I didn't pay full price due to the a/f being out, but I definately want it re-tuned with a working wideband, and I am going to change plugs before I get it done, we'll see where it stands after that.
It might be a few weeks, finals week is coming up and I've got a ton of work to do.
Old Dec 3, 2008 | 06:38 PM
Irocss85's Avatar
im curious too. id do some data loogging first with reg fuel, then with some race fuel. kr or det. will both kill power. it is quite a bit low on power.
Old Dec 15, 2008 | 07:11 AM
ZFSix's Avatar
Put some TR6s in it on Saturday, now I just gotta get it tuned and put a mix in it. Still runs the same after the plug change.
Old Dec 15, 2008 | 09:17 AM
First Collision's Avatar
Fuel probably has a lot to do with it. Take it over to LMR for the tune. They did a good job on my car, and it's a 98... I plan on taking it back with the new setup I'm building. I've heard their dyno reads a little lower than some in the area, but it works very well for tuning.
Old Dec 15, 2008 | 09:42 AM
ZFSix's Avatar
I doubt it's fuel. My fuel system is more than enough for the mods. They sell race fuel there so I will probably put a few gallons in and have Joe tune on it.
Old Dec 15, 2008 | 10:18 AM
Mean Green z28's Avatar
if you wanna play with cams I have a long duration/mid lift cam you can play with for a small amount ... similar to a Trex killer but a bit more duration.
Old Dec 15, 2008 | 02:51 PM
I meant fuel octane, not lack of fuel.
Old Dec 15, 2008 | 03:07 PM
Patrick G's Avatar
LS1 Tech Administrator
The cam is probably not the problem unless it's at some funky intake centerline. I'd highly recommend taking your car to a reputable tuner, one who has a load-bearing chassis dyno and make sure you put the wide-band O2 sensor in a bung just after your headers vs in the tailpipe. You'll get a much more reliable reading. I've seen some really jacked up tunes coming out of Houston that had terrible air/fuel ratios.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 15, 2008 | 03:27 PM
sidewayz28's Avatar
haha. wow that tuner must KNOW HIS ****.
and i bet you signed off a waiver saying if the motor popped on his dyno he would not be held liable?
that tuner is a CHUMP
Old Dec 15, 2008 | 04:19 PM
DONAIMIAN's Avatar
Sadly there's only a few shops that have good tuners in the Houston area. For me personally I feel that I don't really have any other options than learning to do it myself.
Old Dec 15, 2008 | 08:17 PM
  #32
98Aggie's Avatar
Moderator
Are you sure you don't have a dead coil? That would give you a 50-60hp increase. Check each plug with a timing light to see if there all firing.
Old Dec 15, 2008 | 09:50 PM
  #33
ZFSix's Avatar
Wow, what a mature post.
No, I didn't have to sign any waiver. The guy who tuned my car has tuned it 3 or 4 times before and I have had zero issues. The air fuel reading was not working on the dyno that we used, and he would gladly redo the tune for me on a dyno where everything is working correctly.
I doubt it is a dead coil. I would think that would be pretty easy to hear that something was wrong.
Old Dec 15, 2008 | 11:39 PM
  #34
98Aggie's Avatar
Moderator
I've had a car on the dyno before making close to 600 then dropped a coil lost 80rwhp instantly. Should no signs in the data logs and you can not hear anything. Car still ran and idled - a little rough but wasn't blatantly obvious that a coil failed.
Old Dec 16, 2008 | 09:46 AM
  #35
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
Just bring it by when you get a chance. I will take a closer look at it. Sometime I like a challenge.
Old Dec 16, 2008 | 11:01 AM
  #36
ZFSix's Avatar
Yeah I will for sure. I just sold the wheels off of it so it is sitting on jack stands right now... waiting on the new set.
Old Dec 16, 2008 | 09:53 PM
  #37
sidewayz28's Avatar
i try, good luck with the tune
Old Apr 16, 2009 | 04:43 PM
  #38
SStock02's Avatar
ok update i purchased the car. has a new spec 3+ clutch and got tuned put 407hp and 393tq. Now the search continues
Old Apr 16, 2009 | 05:33 PM
  #39
1969mach1's Avatar
you did get a nice car there. somethings up for sure, he was making more power with the stock ls1 as a cam only with the mega death cam from hpe.
very clean car though.
Old Apr 16, 2009 | 05:49 PM
  #40
wht01ws6ta's Avatar
So this is your car now? Who tuned it, the same place? Keep us updated on what you find and good luck because there is a LOT of power missing still.
