Spec me a cam for a high compression 347
Specs:
12:1 347ci shortblock, Wiseco pistsons, Manley rods, polished and balanced stock crank
Livernois Stage II LS6 heads milled to 62cc
Fast 92/PTM 92mm TB
Kooks 1-3/4" headers
42# Injectors
Racetronix fuel pump kit with the hotwire
Right now it has a 236/240 .601/.608 111+2lsa cam. It seems to run decent, but only put down 399.7rwhp and like 386rwtq. Weak!!
I was thinking about the HPE Big E cam, 244/248 .612/.615 112lsa.
Thoughts?
How are you getting 12:1 with 62cc heads, with .01 piston out of hole and .040 gasket, 2cc reliefs, I'm only getting 11.2
Is this a Mustang dyno?
2 different Dynojets, Chuck (formerly of HPE) did the tuning. He has tuned my car 3 times before with no issues. It does run a little rich, but this setup should be making upper 400s, so I doubt tuning is going to get me 80+hp. The first pull untuned was 325hp...
It is a 6 speed also. The clutch grabs a little late but doesn't slip. Also I don't see that making 80hp as well. At first I thought something was off with the dyno so I took it to another shop and the 2 dynos were within 10hp of each other.
The cam wasn't degreed with a wheel, just lined up to 0 degrees with the dot on the other gear. It is a double roller chain.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
What if I put a mix of race fuel in it?
You said it is running rich, that had to be for a reason (clue)
With that compression, you'll want to run some race gas mix in the tank to avoid pinging/detonation. Also a cooler plug like Predator said would be to your advantage!
Unfortunately the wideband was not working when he tuned it... so it was a guess. I am talking to another tuner around here to retune it because I am not happy with the way Chuck did it.
So I am basing it on smelling like fuel, it is horrible standing behind the car, even driving it with the windows down or up you can barely breathe.
Granted, the motor is probably built with heavier then stock components that aren't going to help make power, but you should be seeing in the 450+ range with a stick in the car.
The cam you're running isn't so small that it shouldn't me making a good bit more then it is.
I agree that you probably need some 100 octane gas, probably don't need leaded fuel, but something better then pump is probably needed.
I'd put a set of TR7 plugs in the car, that would be a good starting point as well.
I'll order a set of TR7s and try some race fuel along with a retune and see where it gets me.
But if you are running the o2's the leaded fuel is gonna be a problem, cats, even with unleaded fuel won't be happy either.
cam should not be an issue
TR6 should be a good starting point for plugs
good luck getting it sorted out
....Ask for your money back because you surely didn't get a proper tune without the wide band.
