What is preferred aftermarket cylinder head ?
Which aftermarket cylinder head such as Dart, AFR, Brodix, Edelbrock, etc... seems to be making the most power on naturally aspirated applications ? Do they also flow the most ?
I assume by now, one of the above has silently slipped ahead of the others ?
thank you
thank you
Internet Mechanic
ETP
But the reason why I am quoting is that bear in mind, even the best ported FAST intake flows what, at best 280ish cfm so anything above 300 or so means absolutely nothing and the only time it is going to matter is when there is a Beck intake in it's place your pushing he compression.
For any head choice, the most cfm under the curve and in the useable range of the cam lift.
