Torquer V3 Track Times
Old Dec 4, 2008 | 05:41 PM
1slow98Z28's Avatar
i did 11.94 with LT, 90/90, 3.73, 4000 stall and that shifting at 5900 rpms.... upped it to 6300 for this spring and ill have the M9 in it and coil overs
Old Dec 4, 2008 | 07:02 PM
99 Blue Bird's Avatar
nice time. but was that with the TSP Torquer V3 or the Thunder Racing TRak cam thats in your sig?
Old Dec 4, 2008 | 08:10 PM
chrs1313's Avatar
should put slightly higher numbers than my car...with the right setup i see 10.90s cam only...
Old Dec 4, 2008 | 11:54 PM
Red96TA's Avatar
Originally Posted by 99 Blue Bird
when do you notice it pulling? what rpm range.
The name is decieving, bc it is an ALL top end cam. But thats with my setup which includes a 4000 stall. The lowest I see at WOT is like 5200
Old Dec 5, 2008 | 06:51 AM
holley505's Avatar
Hmmm I guesss a 3500 stall would be good with this cam...
I currently have a 3000 stall
Old Dec 5, 2008 | 08:57 AM
ramairJP's Avatar
Does the V3 have any advance ground in?
Old Dec 5, 2008 | 09:11 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Off the shelf, the TorquerV3 has +2º ground in
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 6, 2008 | 12:03 PM
1slow98Z28's Avatar
I have the TRAK cam basiclly the same as the Torqer V3 but different lobes
I just bought this cam last year for play around time be4 i do a 402 stroker but honestly im thinking bout keeping the cam and building a forged 347 and have a set of darts milled and ported to match the cam and intake and should be a good set up
Old Dec 6, 2008 | 12:07 PM
1slow98Z28's Avatar
http://www.youtube.com/watch?v=XfLRwdb0z_8
video of my car going on the dyno and a run on it.....
made 364 through a 4000 stall... the car made be4 that 310 with bolt on and no stall basiclly all i changed was the cam and went with a 4000 stall
Old Dec 6, 2008 | 12:16 PM
Frank02L's Avatar
I guess theres not usually a PTV clearance issue on the intake side?
Old Dec 6, 2008 | 12:22 PM
1slow98Z28's Avatar
nope if i go to milled heads yes, but with stock heads no
Old Dec 6, 2008 | 12:28 PM
  #32
Frank02L's Avatar
Hmm... Wonder if the LS6 would have an issue eating that lift.
Old Dec 6, 2008 | 04:20 PM
  #33
bad6as's Avatar
not a v3 but my v2 on a 110+3 at 3700lbs went 11.92
Old Dec 7, 2008 | 12:36 PM
  #34
thnks everyone for the input. keep it coming
Old Dec 7, 2008 | 08:13 PM
  #35
holley505's Avatar
I am looking at a TSP torquer V.3 for My New 418 with AFR heads... and CARB..this info helps.
