6.77 @ 102.95 mph with an internally stock LQ4
I am setting up a LQ4 with PRC5.3 heads milled .02 (59cc) with a cam 224/236 609/607 111+2 and LS6 intake. I am hoping for the magic 400rwhp number
That is a pretty quick setup, 6.77 is dooable. Mine was carbed with a 212 224 cam stock 317s and stock lq9 shortblock with good bolts. @ 3420# i went 7.40s on the motor, 6.60s on a 150 shot, and 6.30s on a 200 shot. The 200 shot = 1.38 60' and on motor it was a 1.60-5 60'. 110 was the best mph, it fell off a little on the big end. These stock bottom 6.0s have potential to run pretty quick.
I would say that 360 on a stock cam is possible with a m6
I had 349RWHP with cats on, no underpulley yet, the LS7 clutch(extra rotational weight) and heavy 315 tires on 17 inch rims.
Take the cats off, toss on underpulley, go to a lighter LS1 type clutch, ditch the rims for lighter stockers and maybe a electric pump and easily see those numbers.
Now for a cam car to hit 10's? Mild is a 22x cam as I recall and those usually produce low 12's or 11's if done just right, can't picture the words mild, 10's + gas mileage all in the same sentence unless power adder is also added.
