Piston ?
Old Dec 4, 2008 | 10:11 PM
Bill00Formula's Avatar
Default Piston ?
Just wondered which piston design is best for power and detonation, dome, dish, flat other?
Thanks
Old Dec 5, 2008 | 01:52 AM
First Collision's Avatar
All depends on your plans with the motor... boost, nitrous, N/A? The biggest difference between the 3 is going to be your compression.
Old Dec 5, 2008 | 08:47 AM
briannutter's Avatar
That's easy.. A big big dish prevents detonation. A big big dome is great for horsepower...... Just kidding.
In a perfect world where the chamber can be made small without sacrificing flow, a small reverse dome is the best as the perimeter reflects combustion back into the center momentarily for a more complete combustion. In the real world, Hit the max compression ratio your fuel will withstand. There are some dome designs that do a very good job of enhancing flow around the valve and enhancing combustion.
Thanks, Brian Nutter -Wiseco Piston
