cam 228r
Old Dec 8, 2008 | 07:35 AM
JS01SS's Avatar
Default cam 228r
How many are you guys running a 228r and z06 heads. With a stockblock. Has your gas miliages drop off a lot. Can you feeel the different in the way the car pulls. Thanks James.
Old Dec 8, 2008 | 07:55 AM
toothdoc's Avatar
I have the TSP 228r on the 114 LSA with the stock LS6 heads. You can tell by my signature what this cam is capable of with the stock LS6 heads. My gas mileage is worse by 1-2 mpg than it was with my stock LS1 engine.
Old Dec 8, 2008 | 07:56 AM
NicksTAgt's Avatar
This should explain alot: http://videos.streetfire.net/video/l...run_176465.htm
and that's with stock heads too.
Old Dec 8, 2008 | 09:28 AM
TXZ28LS1's Avatar
it is a very good daily driver cam!! alot of people on this site have that cam, and 0 regrets from the guys that run it.
Old Dec 8, 2008 | 11:03 AM
toothdoc's Avatar
I am looking forward to taking my car to the track in the Spring.
Old Dec 8, 2008 | 12:50 PM
antonio84's Avatar
was that a automatic transmission and what was the lsa on it?
Old Dec 8, 2008 | 05:00 PM
99T/AMAN's Avatar
I have been asking the same thing with this cam?
Old Dec 8, 2008 | 08:26 PM
Phil'sC5vette's Avatar
See sig. Highway driving the car is still great. 25-26 miles to the gallon with 3.90 gears
around town. Not so good. I play with it alot.
it was an easier set up on the LS7 clutch than the textralia clutch
Old Dec 8, 2008 | 09:47 PM
danger ds's Avatar
Never had any problems or driveably issues, and the mid range power is great. An all around proven performer.
Old Dec 8, 2008 | 11:05 PM
kngkahious's Avatar
how much power did your car make and what does it et / mph 1/8 and 1/4 ? thanks. i'm looking to go with close to the same setup you have now plus the bottle. do you like the stall you have now or would you go bigger ?
Old Dec 8, 2008 | 11:22 PM
kngkahious's Avatar
how much power does this cam usualy make on a good tune ? i've noticed in most of your sig's they go from 385-425 rwhp
Old Dec 9, 2008 | 08:35 PM
danger ds's Avatar
My best time to date is 12.18 @ 115 with a 1.86 60ft. the 1/8th mile was 7.83 @ 88.Done at san antonio raceway. I love the stall it drives like stock with no bucking or surging. My cam only was 336HP on the mustang dyno. Its funny your thinking of spraying, i am in the process of looking to do the same. Any more questions let me know.
Old Dec 10, 2008 | 10:16 PM
kngkahious's Avatar
thanks bro , i'm looking at getting the vrx3 cam . it is very close to the cam you have. a 3200 circle d stall , lt's , ls6 with ported tb, and a 150 shot. i'm looking for a solid 10.9x-11.00 pass . if you spray you should be in the same place i am looking to be. that is why i am so intrested . do you have any suspension mods ? what kind of tires were you running on the car? how much did you pick up when you put the stall in the car ?
Old Dec 10, 2008 | 10:37 PM
danger ds's Avatar
The stall help me pick up 1.5 tenths and dropped my 60ft from 2.0 to 1.90 on brand new street tires with out the gears. On that set up i ran 12.50 on the the street tires. When I did gears and ran the mickey drag radials at 18lbs i hit 12.30 on a 1.80 60ft. The car has always been on the stock WS6 suspension from day one not even subframe connectors.
