PRC 237cc Specs / Flow / Pics INSIDE!!
The 237cc port is a supersized version of the 215cc cylinder head that recently claimed the quickest heads cam record!! The 237cc port is designed for customers with 4"+ bore applications looking for a max effort cathedral port cylinder head!
The 237cc cylinder head ships with the following:
- 2.100" Stainless Intake Valves
- 1.600" Stainless Exhaust Valves
- PRC Double Spring Kit (.650" Lift)
- 68cc CNC Machined Chambers
- Provisions for Stock Rocker Arms or Aftermarket Rockers
- Increased valve cover clearance for aftermarket rocker systems
- Thick Deck for better sealing in power adder applications
- 6 bolt option standard for LSx blocks!
- .700" Valve Spring Upgrade Available!!
Flow Data:
Lift Intake Exhaust
.100" 66 cfm 57 cfm
.200" 147 cfm 117 cfm
.300" 225 cfm 170 cfm
.400" 284 cfm 206 cfm
.500" 325 cfm 227 cfm
.600" 334 cfm 235 cfm
.650" 339 cfm 241 cfm
More info available at:
http://www.texas-speed.com/shop/item...d=992&catid=20
Preordering for 215, 227 & 237cc versions available with estimated ship time of mid Jan.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
EDIT: I also noticed that you have the 215cc head on your site twice. I'm guessing that one of them was meant to be the 227cc since you have the 237cc head on there.
Double Edit: If I wanted to set these up with adjustable rockers would they necesitate a special rocker or could I use an off the shelf T&D, Jesel, Comp, etc...?
Jason
2005 Twin Turbo C6
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The cylinder head isn't limited to 13 degrees though, we have options to change this up down the road if we decide to go a different direction.
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
These heads work very well with a ported FAST
A few questions:
1) Flow sheet for the 215cc and 227cc heads?
2) Alot of people looking to run the 237cc version will be doing so on a 4.125"+ bore builds. Can you flow these on a larger bore and put out a flow sheet?
3) Can you give the open/close seat pressure and spring diameter on the .700 lift spring setup?
4) Whats the valve diameter/specs standard? Will these accept only your valves or will they work with a standard LS1 spec intake/exhaust valve in the correct diameter. (If I am wanting to source custom valves for say an Inconel setup etc)
A few questions:
1) Flow sheet for the 215cc and 237cc heads?
2) Alot of people looking to run the 237cc version will be doing so on a 4.125"+ bore builds. Can you flow these on a larger bore and put out a flow sheet? We'll work on getting them flowed on the larger bore after PRI.
3) Can you give the open/close seat pressure and spring diameter on the .700 lift spring setup? These will be very close to the final specs. We are expecting a truck load shipment of the springs today! 160# @ 1.850" and 435# @ 1.150". Coil bind ~ 1.100".
4) Whats the valve diameter/specs standard? Will these accept only your valves or will they work with a standard LS1 spec intake/exhaust valve in the correct diameter. (If I am wanting to source custom valves for say an Inconel setup etc) 1.351" OD of outer spring, .726" ID of inner spring
