Can a 370 outperform a 383?
Old Dec 10, 2008 | 02:18 PM
  #61
gator's 99TA's Avatar
awesome thread. i am writing this stuff down so i can learn more LSX engine stuff!
Old Dec 10, 2008 | 02:30 PM
  #62
TXZ28LS1's Avatar
yeah, im trying to get a better understanding ..but can somebody simplify this stuf...lol.. for instance exactly what is bore and stroke..and then these crazy numbers like 3.905859595 and then 4.0986764..lol.. im trying to understand what all that is.
Old Dec 10, 2008 | 02:40 PM
  #63
XtraCajunSS's Avatar
Bore and stroke for the "traditional" LS1 383 is 3.905" X 4.00" = 383.249 cu. in.
Bore and stroke for the "traditional" 6.0 iron block 370 is 4.030" X 3.622" =369.605 cu. in.
Old Dec 10, 2008 | 02:43 PM
  #64
TXZ28LS1's Avatar
sorry shane, but can u break that down sesame street for me..lol.. like what is 3.905 x 4.00 and this and that.
Old Dec 10, 2008 | 02:46 PM
  #65
brad8266's Avatar
LOL @ TXZ28LS1. Look at his sig.
Old Dec 10, 2008 | 03:01 PM
  #66
TXZ28LS1's Avatar
dude, these are real mods man..lol..
Old Dec 10, 2008 | 03:12 PM
  #67
12secSS's Avatar
My last 370 which was a complete load of junk parts picked up from around the shop with a set of crap cylinder heads made 481RWHP through a 9" with 4.57 gears and no dyno tricks. Piston to bore clearance was .0095", it ate a quart of oil every 4-500 miles... etc... etc...
Try and do that on a 383 LS1 with the same bull$hit combo of parts...
Shane
I had a similar experience. But I used parts from my left over 346 H/C package on our race car with a temporary LQ4. Through a TH400 w/4500 stall, 12-bolt 4.11s this 242 cam and ported 241 heads (~10.4:1 CR) made 494 rwhp. On the same dyno, a customer had a PRC headed 383 (11:1 CR) 239/244 cam and made 475 through an M6 C5.
Not saying the PRCs were bad or anything, just both setups were not optimized and the 4.00 bore made better power.
Old Dec 10, 2008 | 03:24 PM
  #68
3.905" is the diameter of the bore of one cylinder. 4.00" is the distance the piston travels in 1 "stroke" of the bore. By using a simple mathmatical formula for the volume of a cylinder the multiplying the result by 8 cylinders, you get the total displacement of the engine.
One common way to express this formula is:
displacement = pi x (bore/2)^2 x stroke x number of cylinders
Thanks,
Shane
Old Dec 10, 2008 | 03:26 PM
  #69
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by 180ls1
maybe i misunderstood then, but an optimized engine with more cubes will make more power then one optimized that has less cubes.
There is the source of your misconception. Fully optimized, more cubes should make more power, no one will deny that. Optimized, however, includes bore x stroke. The LS1 block 383 by design is inherently flawed with a small bore and long stroke, and can never be fully optimized because of that. Without an optimized bore x stroke, you're simply trying to make up for a undersquare setup when you put a great top end on it that you would consider the the "best setup."
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Dec 10, 2008 | 03:36 PM
  #70
180ls1's Avatar
Well that is what the entire thread is about. 383 vs 370, which is basically a bore vs stroke arguement. More bore gives you better head options. Better head options allow you to massively overcome the slight difference in displacement.
yes that is correct but the thread strayed from that and that is what i commented on. I know that the head options for a 370 block give a big advantage i was just trying to clear up what bigbroncoss was saying where other people think he was saying something else.
Originally Posted by z28mccrory
I think you only understand a small portion of what is being said here.
not at all chief.
Originally Posted by Matt@Texas-Speed
180ls1: I do agree that you've misunderstood alot of what is being said in the thread. You're still in bigger is better mode. That's not always the case, and its been shown in this thread with math (not just opinions, actual formulas that dictate the subject).
Brad summed the thread up very well in his post, quoted below.
i dont think you understand what i am getting at. I know bigger is not always better like i said earlier. But when you have an engine that is slightly bigger and the components increase flow in perportion with the increase in size it will make more power then the smaller engine. That is not the case here but i wanted to make that clear. Hope that helps.
and sorry to the op if i took this thread off topic.
Old Dec 10, 2008 | 03:51 PM
  #71
z28mccrory's Avatar
not at all chief.
Your argument has nothing to do with the debate in this thread. I dont think you understand the bore argument. A 4.00 bore will always flow more than a 3.9" bore. At the end of the day the 383 in discussion could never flow as well as the 370 in discussion. This isn't something you can just vaguely say "well you have to have the right combination".... the combination (bore and stroke) is fixed in this debate. All you are doing is confusing youself.
Old Dec 10, 2008 | 05:32 PM
  #72
1989GTA's Avatar
Doing the math the bore on the 370 is .125" larger than the 383 motor. That is bigger than I thought and would alow for a lot more air flow.
Old Dec 10, 2008 | 05:42 PM
  #73
z28mccrory's Avatar
How is 4.000 minus 3.900 a difference of .125?
Old Dec 10, 2008 | 05:47 PM
  #74
Damian's Avatar
LSX Mechanic
THANK YOU SIR.
I was going to say this earlier, but I didn't want all the 383 owners to get their feelings hurt.
  #75
A 370 is actually a 4.030" bore and the 383 is a 3.905" bore. 4.030 -3.905 = .125
Shane
Old Dec 10, 2008 | 05:52 PM
  #76
z28mccrory's Avatar
A 370 is actually a 4.030" bore.
Shane
Sorry i wasn't more specific... im well aware of that... just wanted to stress the fact that its not 1/8" difference
Old Dec 10, 2008 | 05:56 PM
  #77
180ls1's Avatar
you are wrong read through it again please. The issue about bore size is what the op brought up, i was talking about cubic inches which is contained in this thread also which was not even brought up by me. like i said read it again.
Old Dec 10, 2008 | 06:00 PM
  #78
z28mccrory's Avatar
BORE SIZE DIRECTLY EFFECTS CUBIC INCHES.
In this case your argument is null and void.
You are like talking to a porpoise and i dont understand "squeaks" and "clicks".
Old Dec 10, 2008 | 06:04 PM
  #79
180ls1's Avatar
see you are not even trying to understand what i am saying you just want to be right. do you really have that hard of a time trying to understand what i am saying?
Old Dec 10, 2008 | 06:17 PM
  #80
z28mccrory's Avatar
What you are saying has nothing to do with the argument at hand.
Cubic inches only matter if there is the bore there to support it. IN THE CASE WE ARE TALKING ABOUT... the 370 has a bore that will support more power than the 383... and will make more power every time.
If your argument is "Cubic inches always make more power assuming the bore is the same" then i agree... who wouldn't... thats stating the obvious.
