What caused my power loss?
Two years ago I had a lifter tray break and I thought I'd dump the plastic trays and go with a rev kit. Rev kit worked for about a year and then it cracked, either due to poor directions, poor installation, and/or poor quality, so I went back to the plastic trays due to cost.
I finally dyno'ed the rebuilt motor last weekend. Between the motor with the revkit and the current motor with the plastic tray, I lost 10-15rwhp across the entire RPM band, with basically an identical AFR. We dropped the AFR a full point and it changed +/- 3rwhp across the entire power band.
Old:
Piston rings gapped by me
Rev-kit
Comp LSK 227/235 .645/.650 110+2
Cadillac lifters
German Castrol 0W30
Bearing clearances may have been a little looser
Now:
New rings, identical part number, gapped by locally renowned LS1 speed shop
OEM lifter guides
Comp XFI 226/232 .604/.609 110+2
Catch can
LS7 lifters
Redline 10W40
Re-used previous PRC Platinum springs after all were tested and were still like new
Bearing clearance may be a bit tighter
Obviously I'm irked. Could the LSK cam really be that big of a difference? I still have that LSK cam in a box but it has a little bit of wear on one lobe. I considered sending it back to Comp but convinced myself nothing would come of it so I didn't.
Old:
Rev-kit
Cadillac lifters
German Castrol 0W30
Now:
OEM lifter guides
Catch can
LS7 lifters
Redline 10W40
I wouldn't care as much if it was just on the top end, but I want torque throughout the whole powerband for autox and roadracing. 410rwhp/378rwtq (SAE) or 420rwhp/389rwtq(STD) is phuckin weak for the money I've dumped in this motor. Used the same dyno. Maybe I need to start fresh with a complete new longblock instead of repairing the current block as things break.
