iron 370ci main bearing clearances
#2: .0015-.0018"
#3: .0012-.0015"
#4: .0015-.0018"
#5: .0015-.0018"
Measurements were taken w/plastigauge, hence no dead nuts number. The motor is a iron 370ci with coated bearings, it'll be street/strip, shifted at 7000rpm and a 150 shot a few times a year. Probably ~475-500rwhp on motor. Are these clearances too tight? I wouldn't bat an eye if it was an aluminum block, but not sure w/iron. If they're too tight, what's the best way to fix?
Usually, I like to see a little higher like .0022-.0030" depending on the application. You can take the crank to a crank grinder and have him turn the crank down to get the clearance you want. With .0015" of clearance, I'd have the crank turned .001" for .0025".
