Oil Pressure Problem Fixed!!!
Old Sep 27, 2003 | 02:23 AM
Camaro01SS4life's Avatar
Default Oil Pressure Problem Fixed!!!
Before I did the swap I had very bad oil pressure...40psi at cold idle, 25-30psi for hot idle...Cruising around, about 40psi...
When I disconnected the pick up tube to the oil pump, 1/4 of the O-Ring was gone ...It appeared that it had ripped off...So I replaced the O-Ring and the pump(TR Ported LS6 Oil Pump )...Now I have 60psi at cold idle, about 45psi for hot idle...Cruising around about 55-60psi...I thought I would share my experience, since people seem to be having problems with there oil pressure...
Kevin
