cam suggestions?
Old Dec 19, 2008 | 06:49 AM
02anti_vnm's Avatar
Default cam suggestions?
ok guys im looking to put a bigger cam in my car the one i have now isnt bad but i just wana go bigger and spray the car... here is what i have a 2002 ss camaro m6 with 241s milled .037 and a 3 angle valve job fast/nw 92mm combo 228/232 .612 .600 111 lsa cam fly cut pistons all the supporting mods .650 lift springs hardened pushrods pro magnum lifters also the car has 4.56 gears and i wana spray it with a 175 shot. this car is strictly a street car and will prob. never see the track and isnt a daily driver. i wana go bigger im thinking a t-rex v.2 what do yall think any other suggestions?
Old Dec 19, 2008 | 09:35 AM
chrs1313's Avatar
you are going to have to go pretty big to see a difference in what u have now...i would guess the trex will only give a max of 10-15rwhp over what u have now and u will need to spin it to at least 7K rpms...
that can trex is make to be a track cam, what i mean by that is it is designed to run only from 5k-7k that is where it really shines...so it give up the drive ability in the lower rpms...now any cam can be street driven but i got a feeling you are going to regret the switch after you do it...
there is so much more gained from the rest of the setup over just switching the cam...what i mean is you can add a ram air like a sux2bu or one like i got and add 25rwhp...that is more than any cam swap is going to give you....
https://ls1tech.com/forums/generatio...sults-tom.html
look at my cam pretty similiar to yours, you can get high 10s out of it, and i dont have a fast 90/90...
if you are dead set on getting another cam that is a max effort track cam, also look into the g5x4...again these are not very street friendly...and wont add that much more power...
Old Dec 19, 2008 | 09:45 AM
Patrick G's Avatar
LS1 Tech Administrator
If this is strictly a street car, then traction is your enemy. Sometimes in a street application, it helps to knock a little bottom end out of the car to allow it to hook up better. I'd recommend going bigger on the intake and quite a bit bigger on the exhaust. An earlier EVO will help a lot on the nitrous, it will knock some bottom out of the motor and allow it to carry the rpm further past your power peak. The resultant LSA could very well be wider than your current cam. Just depends on your desired shift rpm and rev limiter.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 19, 2008 | 09:59 AM
teke184's Avatar
wouldn't there be more power to be gained from improving the heads?
although that may be more money than you wanted to spend.
Old Dec 28, 2008 | 08:43 PM
02anti_vnm's Avatar
ive decided to go with a poluter and just spray a 150 wet shot but thanks for the advice guys!
