Biggest cam for my setup.
Old Dec 24, 2008 | 10:30 AM
TransAmcoupe98's Avatar
Default Biggest cam for my setup.
I have a good friend who is selling me an almost new 238 248 cam for $150. We called Compcams and they said that cam is pretty big but it would work awesome, but I was talking to a friend and he says the bucking and surging would be a big issue unless I put at least 4.11's in the rear. My concern with the gears is driving home to TN form Tampa, FL. I dont want to be running 3000 rpm all the way home. Should I go with a smaller cam to kepp that down or will I be ok with my stock gears...
Old Dec 24, 2008 | 10:39 AM
SOMbitch's Avatar
410/411's are optimal for that setup but with a good tune you will be fine. But GOOD tune is the key. I think tuned right it won't buck/surge at anything over 1800/1900.
410/411's were made for that cam though so get'em in there ASAP. It will make that beast a whole new car
Edit: See JF tuned your car. I would DEFINITELY get him for the retune......
Old Dec 24, 2008 | 01:44 PM
chrs1313's Avatar
the cam is not worth it for the street...look into something smaller
Old Dec 24, 2008 | 01:58 PM
slowandrichws6's Avatar
dude get that cam and if you dont then go bigger!!! i am runnin 4.10's and i barely get above 2000 rpm on the interstate. good luck!!
Old Dec 24, 2008 | 03:06 PM
LS1-NAVY's Avatar
all you need is a good tune and there should be no bucking or surging
Old Dec 24, 2008 | 06:27 PM
JohnHF's Avatar
the bucking and surging mostly comes into play in the lower gears where torque multiplication has more of an effect. with a good tune 6th gear shouldnt have driveability issues with a big cam
